ok I've given up for now.
Of course I had not, whom was I trying to fool?
I knew it was possible.
I managed to disable the signature verification subsystem altogether.Now we can run anything signed with an arbitrary key with system privileges.
1. Pull /system/framework to a computer
2. Deodex the /system/framework/services.jar component (I used
https://github.com/jareddantis/simple-deodexer, as it's simple indeed, and I didn't want to install any full blown IDE: it deodexed everything, but we only need services.jar)
3. Decompile the deodexed services.jar using e.g. apktool
4. Modify the methods responsible for signature verification in
smali/com/android/server/pm/PackageManagerService.smali, basically we need to make the methods
compareSignatures,
compareSignaturesCompat, and
compareSignaturesRecover unconditionally return zero, credits to
https://xdaforums.com/t/guide-superusermod-disable-signature-verification-nougat-mm.3549952/, the new code to put there can be found there as well.
5. Recompile services.jar using apktool.
6. Replace the original /system/framework/services.jar with the patched version, remove
/system/framework/oat/arm64/services.odex, and, just in case, remove the respective cache file in /data/dalvik-cache/arm64
7. Reboot (I actually had to power cycle the scope)
8. Ready to install and use self-signed apps. For webcontrol I had to not only
pm uninstall it (with both "--user 0" and without it), but also remove it from /system/app/Webcontrol.
Needless to say, keep a backup of the sd card image handy and know how to restore (by mounting the respective fs and restoring individual files -- usually there's no need to restore the whole image) when things go wrong.
Now, my webcontrol streams a 1024x600 picture, as it should. Picture quality is better than the original 1280x800, but it's still lossy: I believe it uses jpeg/mpeg or some other lossy compression algorithm. I will try (and encourage others to try) to find where it may be configured to have a proper lossless picture. Stream rate is currently below 2 Mbit/s, so there's plenty of headroom not to require any compression at all.
Attached (as zip, to avoid the forum's image format conversion) is an example of the webcontrol stream. You can clearly see the compression artifacts.
p.s.
we may not need the stock webcontrol app at all. I haven't searched yet, but there must be better android apps for screen sharing which we could potentially install.
