If anyone is interested, I have attached two files. These are boot logs read from the UART connectors of the processor and FPGA.
Thanks for posting these. Have you diff'd these to the original logs Dave posted that he took during the teardown video? Has much changed? I'll check in "the morning" when I get up. ![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
No, I didn't compare. I didn't even look closely at what I recorded from my oscilloscope ![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
Huh. Interesting.
Aside from the Garbage characters at the beginning and the occasional line break diff, not much changed in the FGPA console outputs. Not totally surprising, but a tad bit disappointing that they haven't found
something to fix. Maybe their VHDL team is
that good....?
On the RK side; Even though dates/versions are same, there are many more white space diffs, and there seems to be several lines not matching up -Altho', admittedly I'm just doing a quick compare using a subpar diff tool--Chrome extension POS. Hard to tell what's missing, and not.
Did you edit/add anything in your bash scripts?
If you don't mind sharing; What is your model # and month built?
