Speaking of additional calibration options.. I hadn't noticed this before tonight. There is a "Detail" drop-down on the SelfCal window with some interesting calibration info. -if it passes-
(Attachment Link)
BTW: these are all the "additional calibration" options that I found to calibrate with success. Anything else added will fail.
(Attachment Link)
FYI: it took 7 hours to test all the permutations, because some would go 98 or 99% before stopping or crashing.
The cal items seen after x3 About press, is a bit confusing. Are the ones selected by default the same items used when you just have the std Cal menu of "start"? Or is the std set something different? Is that in the manual?
Rigol should at least identify which ones selected are in the std set of cal tests. And why does selecting the other tests fail? If they are tests not applicable to the device then they should be grayed out. If they are applicable tests and they fail, why do they fail?
From my photo; The bottom row of SelfCal items are not selected in a factory stock configuration(at least with my 804), and I doubt there's any reason to believe there's any differences related to SelfCal between authentic 800 and 900's, since they use the same software package.
Through many hours of calibration testing, I was able to figure out you could also do each of the items in the bottom row without premature exit failure.
I captured the default 1, 2, 3 SelfCal screen before I did this testing.
Why do some items fail SelfCal? Might be able to capture that info in the log file. and, FWIW as I mentioned the "interesting details" triangle has a log as it's calibrating, as I showed in that pic. Maybe it's there. Or via Serial terminal... or k(d)mesg.last, or logcat, etc... (you're the Android expert, not me!)
