Don't use dd, use ddrescue.
If there is no problem with reading data, then dd, ddrescue and cp will do same job. cp cant do offsets but its faster.
And somehow you know that every block on a block device are ok? And just to be clear,
not everything is a "file". Block devices can be a file, they can also be ext hardware like sdcard, or spindle drive, or ssd.
The /dev/[files] are mappings, this however does not mean my /dev/sda is a img file somewhere on a mounted filesystem, it could be ext attached hardware.
When I image a disk to /home/myimage.img, "stat myimage.img" shows inode "reg file". If I map that img to /dev/loop9, "stat /dev/loop9" shows inode block device. 100% all files. This is not the same as /dev/sdb that maps to my USB sdcard.
dd has limitations, gddrescue, ddrescuew, and a few other "ddrescue" variants get beyond some putfalls of dd.
If it's a file, dd should be problem free. If it's hardware then something other than dd is a better choice.
