Author Topic: Hacking the Rigol DHO800/900 Scope  (Read 1626141 times)
0 Members and 27 Guests are viewing this topic.
Offline norbert.kiszka
Re: Hacking the Rigol DHO800/900 Scope
« Reply #2100 on: March 12, 2024, 03:03:39 pm »
I disassembled it through APKLab
I was using APKLab, but previously it was disassembled by apktool (without APKLab) Maybe thats the reason.
maybe you changed the .java files
Only one .java file also, but mostly files as I said before.
Offline AndyBig
  • Country: ru
« Reply #2101 on: March 12, 2024, 03:18:04 pm »
BTW. FPGA Image from DHO1000 works, however after reflashing I see no changes - not at all. BTW2. PLL is driven by a kernel module.
The DHO1000 has a completely different FPGA (Artix) and its firmware (configuration) cannot work on the FPGA in the DHO800/900 (Zync). There are no changes, probably because foreign firmware is not accepted by this FPGA and its native firmware is loaded into it.
The following users thanked this post: egonotto, AceyTech
Offline AndyBig
  • Country: ru
« Reply #2102 on: March 12, 2024, 03:19:53 pm »
Yes, most likely because of this.
This is useless, .java files are not compiled when building :)
Offline Randy222
« Reply #2103 on: March 12, 2024, 03:23:07 pm »
However... Now i tried to move generated apk into another folder, unpack+dissasemble it and rebuild it back - looks like it works (because of crash...). Of course that is not good way to test changes.
I haven't encountered anything like this. I disassembled it through APKLab, and put it back together through it - everything worked.
apklab, apkeditor, and apktool all work for me. Each has it's quarks. Realign zip (apk) and signing I do on a windows machine that has android studio and the platform & build tools.
« Reply #2104 on: March 12, 2024, 03:27:00 pm »
Maybe Im wrong, but its the same datasheet. And it works - currently I dont see completely any changes after that.
EDIT: Yeah, I missed last part of Your post. "...firmware is not accepted by this..."
« Last Edit: March 12, 2024, 03:33:21 pm by norbert.kiszka »
Offline AndyBig
  • Country: ru
« Reply #2105 on: March 12, 2024, 03:29:06 pm »
I settled on VS Code + APKLab as the most convenient option. And it’s convenient to edit files, and all build processes are automated :)
Offline Randy222
« Reply #2106 on: March 12, 2024, 03:34:46 pm »
If You select msdos partition table before quick search, then testdisk will assume 4 root partitions at max. Try to select GPT.
If You want to find much more things, then use binwalk.
Yes correct, the partition layout, even if there is no partition table as such, appears to be GPT:
Disk sd-card-image - 31 GB / 29 GiB - CHS 3857 255 63
     Partition               Start        End    Size in sectors
>P Linux filesys. data       548864     811007     262144
 P Linux filesys. data       811008    5005311    4194304 [system]
 P Linux filesys. data      5005312    5038079      32768
 P Linux filesys. data      5047360    6071359    1024000 [rigol]
 P Linux filesys. data      6299648   61951999   55652352
I made image of sdcard and then connected it to /dev/loop9, ran testdisk on that device.
I get the same as you show here, but did you try to use the p, c, and C hotkeys on any dir or file? I can see filenames and such in the various slices testdisk shows, same structure as in the live DHO, but when I try to copy out a file the C just places an empty folder.
Even after testdisk can you mount the block device ?
Also noted, when I run testdisk on that loop9, it throws a warning "the partion table detected is GPT EFI, do not select none".
« Last Edit: March 12, 2024, 03:37:31 pm by Randy222 »
« Reply #2107 on: March 12, 2024, 03:37:39 pm »
Nah.. I used offsets shown in testdisk to mount it using another terminal emulator.
Edit: testdisk works directly from a image file - I dont see any point to use loop.
Offline AndyBig
  • Country: ru
« Reply #2108 on: March 12, 2024, 03:41:53 pm »
No, they are quite different. The Zynq Z-7015 (DHO800/900) has a much less powerful FPGA than the XC7A100T (DHO1000). Not to mention that Zynq has an additional integrated processor core.
Offline Randy222
« Reply #2109 on: March 12, 2024, 03:43:09 pm »
Don't use dd, use ddrescue.
If there is no problem with reading data, then dd, ddrescue and cp will do same job. cp cant do offsets but its faster.
And somehow you know that every block on a block device are ok? And just to be clear, not everything is a "file". Block devices can be a file, they can also be ext hardware like sdcard, or spindle drive, or ssd.
The /dev/[files] are mappings, this however does not mean my /dev/sda is a img file somewhere on a mounted filesystem, it could be ext attached hardware.
When I image a disk to /home/myimage.img, "stat myimage.img" shows inode "reg file". If I map that img to /dev/loop9, "stat /dev/loop9" shows inode block device. 100% all files. This is not the same as /dev/sdb that maps to my USB sdcard.
dd has limitations, gddrescue, ddrescuew, and a few other "ddrescue" variants get beyond some putfalls of dd. ;)
If it's a file, dd should be problem free. If it's hardware then something other than dd is a better choice.
« Last Edit: March 12, 2024, 03:47:54 pm by Randy222 »
Offline Bob_McBob
« Reply #2110 on: March 12, 2024, 03:45:44 pm »
I've tried to go through the thread, but it's a little daunting reading so many pages of posts. Is the bandwidth and memory hack stable enough that there's no point spending the extra on the DHO814 instead of the DHO804? I saw a recent comment on Youtube that someone was having issues applying it to the latest firmware, is that going to be a problem?
Offline AndyBig
  • Country: ru
« Reply #2111 on: March 12, 2024, 03:47:16 pm »
No, you can easily get 814 from 804, and even 924 with full bandwidth.
« Reply #2112 on: March 12, 2024, 03:48:27 pm »
Im using cp to flash SD cards (and other devices) without any problems so far.
https://www.mouser.com/pdfDocs/zynq-7000-product-selection-guide.pdf
Maybe it is, but (probably) nobody tried to dissasemble it to see what was changed between those scope series.
Offline Randy222
« Reply #2113 on: March 12, 2024, 03:50:18 pm »
mounted using what type of filesystem?
I was trying to mount the loop block device.
Emulator? We can use losetup with offset and sizelimit switches. I try that next.
« Last Edit: March 12, 2024, 03:58:05 pm by Randy222 »
Offline Randy222
« Reply #2114 on: March 12, 2024, 03:53:42 pm »
As mentioned, yes.
If you want 4ch 800, get the 804 and turn it into a 924. That's how my 804 runs.
It's not hard, a bit tricky though, you really need to know adb and how to connect via ssh. The tool created by zelea2 runs directly on the dho.
Once you get access to the dho, adb pull the various files for backup reasons. The whole process is rather painless.
Offline AndyBig
  • Country: ru
« Reply #2115 on: March 12, 2024, 03:54:13 pm »
No one has tried to disassemble the DHO1000? Of course someone tried :)
« Reply #2116 on: March 12, 2024, 03:56:03 pm »
One of my reasons why I did buy 924S was different passive probes (350 MHz instead of 150 MHz) included.
mount -t ext4 imageFile.bin /mount/point -o offsetAndSizeOptions
In past years something was changed and I dont need to add option loop - mount does this automatically.
adb root
adb shell
So there is no need to use ssh at all.
The following users thanked this post: Randy222
« Reply #2117 on: March 12, 2024, 04:00:02 pm »
I meant flash binary, not scope teardown.
Offline AndyBig
  • Country: ru
« Reply #2118 on: March 12, 2024, 04:03:35 pm »
Ah, got it. Here's another disappointment - parsing the FPGA configuration binary is almost impossible, at least for any practical purpose.
Offline Randy222
« Reply #2119 on: March 12, 2024, 04:05:50 pm »
adb root
adb shell
adb is a bit clunky, unless you use an add-on gui app.
I use putty for ssh, open putty, dbl-click my "rigol" profile name, i'm in.
I only use adb to push and pull files, and where bin tools in ssh have been deprecated and can only be used via adb, like package lists, need to use 'adb shell cmd package'. I said it before, Android is a wonky system, way overly convoluted, but I guess goole needed to say they had their own linux OS.
« Reply #2120 on: March 12, 2024, 04:12:49 pm »
adb shell works little slow (I didnt compare it to ssh beacuse I didnt use it on this scope) if You meant this.
Putty - so looks like You are using Windows. That also can make difference.
About Android, yeah, they took Linux kernel and they made Windows 3.11 from it. Thats why I made my Debian build to work on this scope - but X is little unstable, with same error in logs after every crash.
Offline Randy222
« Reply #2121 on: March 12, 2024, 04:55:06 pm »
[/code]
Ok, I found it.
It's 512 setcor size. So, when mounting using the START number found from testdisk, offset for mount is really     -o offset=$((512* [start number]))  , so example somethig like mount -t ext4 -o offset=$((512*811088)) [PATH_TO_IMG] [PATH_TO_EMPTY_DIR]
So for readers here, image the sdcard (I use ddrescue or the like, not dd), then you can run testdisk on the image (choose EFI/GPT a partition header type), do "anaylse" to find the START numbers of the slice, then you can mount that slice per above. Best to view the slices using the 'p' hotkey to see if the slice is empty or not, as there's no reason to mount an empty slice.
« Last Edit: March 12, 2024, 09:15:01 pm by Randy222 »
Offline S2084
  • Country: cz
« Reply #2122 on: March 12, 2024, 04:59:33 pm »
I have 924S, later I will do some photosmodules
@norbert.kiszka I still dare to remind you.....
« Last Edit: March 12, 2024, 05:01:40 pm by S2084 »
« Reply #2123 on: March 12, 2024, 06:52:08 pm »
As for now I never removed heatsink. I was going to modify one channel, but I didnt. Also I cant find thermopads - Im not sure if I can reuse existing ones after heatisnk removal (maybe clean them with isopropyl?).
Anyway, I just did two photos just above heatsink. If You need something more (right now without removing heatsink), just give me a sign.
If You going to change only HW number, then read my previous posts about it, because You can change it in "soft" way, without changing resistors or decompiling anything.
Offline Randy222
« Reply #2124 on: March 12, 2024, 06:53:00 pm »
After some sdcard edits, got my scope back.
I believe this older droid uses sdcardfs on android_meta and android_expand partitions. sdcardfs apparently is a layer that does not use block addressing.
From what I know of and read about sdcardfs, ext4 is the underlying filesystem. Yep, android is as goofy as they come.
Another interesting note, vold has expand encryption keys in /data/misc/vold dir
