That's interesting. I was wondering if anyone put a 814 model number on their 802 scope to make a 3ch scope. Good to know! Thanks for sharing the pic of the DHO802 Ext/Ch4 AFE. FYI: once you enable the testmodel option, you might be able to play with your 4th ch offsets YMMV, standard disclaimers apply.
Made 812 into 924. The 4th channel is there (blue) but is not synchronized, the trigger does not work. I turn on the control of the CH4 trigger and the “T” cursor does not move, “SINGLE” also does not work.
You can't view them.
There is no partitions record.
I see how partition was extracted with some script (sorry can't remember who make it)
Then what addresses are passed to kernel and see that is an offset for what we know from script and that.
My scope is still on pieces.
If anyone can check with mount command if there are more.
It may be that at runtime others to be "mounted" but they are more or less just empty.
It may be possible to build partition table and Android doesn't upset.
When analyzing the situation, two places were found on the oscilloscope board that can determine the HW version and thus determine the behavior of the oscilloscope program. These are resistors near the input front end of channel 4, and resistors on the bottom side of the board in the processor area.
rockchip-key {
compatible = "rockchip,key";
status = "okay";
io-channels = <0xc7 0x1>;
vol-up-key {
linux,code = <0x73>;
label = "volume up";
rockchip,adc_value = <0x1>;
vol-down-key {
linux,code = <0x72>;
label = "volume down";
rockchip,adc_value = <0xaa>;
power-key {
gpios = <0xc8 0x5 0x1>;
linux,code = <0x74>;
label = "power";
gpio-key,wakeup;
menu-key {
linux,code = <0x3b>;
label = "menu";
rockchip,adc_value = <0x2ea>;
home-key {
linux,code = <0x66>;
label = "home";
rockchip,adc_value = <0x163>;
back-key {
linux,code = <0x9e>;
label = "back";
rockchip,adc_value = <0x230>;
camera-key {
linux,code = <0xd4>;
label = "camera";
rockchip,adc_value = <0x1c2>;
That's interesting. I was wondering if anyone put a 814 model number on their 802 scope to make a 3ch scope. Good to know! Thanks for sharing the pic of the DHO802 Ext/Ch4 AFE. FYI: once you enable the testmodel option, you might be able to play with your 4th ch offsets YMMV, standard disclaimers apply.There was such an attempt. According to a post from someone who was trying to make a 924 out of his 812 by changing the model name in vendor.bin, the CH4 channel appeared and displayed a trace, but it was impossible to set a trigger on it.
Here is his explanation:QuoteMade 812 into 924. The 4th channel is there (blue) but is not synchronized, the trigger does not work. I turn on the control of the CH4 trigger and the “T” cursor does not move, “SINGLE” also does not work.When analyzing the situation, two places were found on the oscilloscope board that can determine the HW version and thus determine the behavior of the oscilloscope program. These are resistors near the input front end of channel 4, and resistors on the bottom side of the board in the processor area.
Do you have a link to that 812 -> 924 post? Maybe I'm not looking at the right thread.
Somebody did a measurement of its values?
I lost incredible amount of time to modify kernel 5.x to make it work. But that made me possible for me to make 4.4.179 fully working as it should.
HDMI now works as a separate screen. Of course itcanwork as a mirror.
Another drawback of the modified application was discovered - it is denied access to external storage, that is, to a USB flash drive. Because of this, the application gives an error when loading if the flash drive is plugged into USB. And you cannot save screenshots to a flash drive.
I looked at how the flash drive is mounted, the user root and group sdcard_rw are assigned to it.
It seems that moving the application to /system/priv-app does not solve all the issues. This gives access to the API, but does not give access to resources. I think that a possible solution could be the method suggested by @Randy222 - editing the platform.xml file.
@AndyBig; Have you tried replacing the sparrow.apk in an update.GEL with your modified one, and apply it like a standard "update"? I'm wondering if the system might not reject the modified app if applied like this vs. ADB install method.
A few of updates for the crowd:
3)a flaky off-white residue all around all of the BNC input areas. I suspect dried washing solution, but that can't be too good for impedance.
4) I am not big fan of thermal pads, so I added a ball of my heatsink paste above and below each pad. And not to worry, each ball is size properly for the size of the chip, there will be no leaking over the edges.
5) Two of the heatsink screws were not tight at all. They all went back in using some lightweight threadlocker.
Onto questions:
I took sdcard to my linux system, it will recoginze 16 disk slices as /dev block devices, but they will not mount and fdisk won't show anything. I never checked, but is the sdcard encrypted? Is anyone successfully mounting the slices on sdcard, and if so how are you doing that?
3)a flaky off-white residue all around all of the BNC input areas. I suspect dried washing solution, but that can't be too good for impedance.Probably solder flux residue. Happens with hand soldered thru-hole parts when they don't spot clean the area after assembly. Even using "no-clean" flux.Quote4) I am not big fan of thermal pads, so I added a ball of my heatsink paste above and below each pad. And not to worry, each ball is size properly for the size of the chip, there will be no leaking over the edges.You essentially ADDED additional thermal impedance by adding a layer of compound with the pad. May help, may hinder. YMMVQuote5) Two of the heatsink screws were not tight at all. They all went back in using some lightweight threadlocker.Threadlocker? You're never going back in? Well, clearly they didn't torque the screws during assembly. Shame.QuoteOnto questions:
I took sdcard to my linux system, it will recoginze 16 disk slices as /dev block devices, but they will not mount and fdisk won't show anything. I never checked, but is the sdcard encrypted? Is anyone successfully mounting the slices on sdcard, and if so how are you doing that?SDCard is not encrypted. I've had good luck using "testdisk" on Ubuntu. People talk about mounting using loopback, which I haven't tried.
FYI: Here are a couple links from searching for "partition" (just the highlights)
Sept:
https://www.eevblog.com/forum/testgear/rigols-new-dho800-oscilloscope-unbox-teardown/msg5048008/#msg5048008
More:
https://www.eevblog.com/forum/testgear/rigols-new-dho800-oscilloscope-unbox-teardown/msg5046892/#msg5046892
Dec:
https://www.eevblog.com/forum/testgear/hacking-the-rigol-dho800900-scope/msg5240010/?topicseen#msg5240010
My post about SDCard partitions:
https://www.eevblog.com/forum/testgear/hacking-the-rigol-dho800900-scope/msg5356541/?topicseen#msg5356541
Most recent, from 3 days ago:
https://www.eevblog.com/forum/testgear/hacking-the-rigol-dho800900-scope/msg5374955/#msg5374955
I'm having trouble getting RigolTool working.
But If I start the app, the initial screen appears, then shuts down after 2 seconds.
I tried running as admin...
I am using Windows 10.
I'm using adb commands, but its a pain.
The solder job on the BNC connector pins looks really good, but the area right around the pins look really clean, and I doubt they brush or use liquid flux, probably just pop in the connector and solder. So I guessing it's from the solder. Also a bit odd it's in a crescent shape around the 3 pins. Whatever it was, it's gone now, for the better.
I'm using adb commands, but its a pain.i'm experiencing the same issue. but last time it was working i can view and download some files with ease, i think i updated Windows 10 with something that made its not working. any new version of RigolTool?
ref: https://www.eevblog.com/forum/testgear/hacking-the-rigol-dho800900-scope/175/
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 coherent_pool=1m cma=257M androidboot.baseband=N/A androidboot.selinux=disabled androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x0000C000@0x00010000(kernel),0x00010000@0x0001C000(boot),0x00020000@0x0002C000(recovery),0x00038000@0x0004C000(backup),0x00040000@0x00084000(cache),0x00400000@0x000C4000(system),0x00008000@0x004C4000(metadata),0x00000040@0x004CC000(verity_mode),0x00002000@0x004CC040(baseparamer),0x00000400@0x004CE040(frp),0x000FA000@0x004CE440(rigol),-@0x00600000(userdata) storagemedia=sd androidboot.oem_unlocked=0 uboot_logo=0x02000000@0xf5c00000 loader.timestamp=2023-08-23_11:38:38 SecureBootCheckOk=0
mount -t ext4 sdcard_dho924s.bin /some/empty/directory -o offset=3225419776,sizelimit=28494004224
Are you planning to port out all the Android stuff to native Linux OS? This would seem like a big to-do.
Another option is to compile Qemu for your dho linux, and then just run the whole dho android in that emulator. But I am not sure what the benefits would be because all the Rigol stuff would need to run through a vm layer to get to hardware, and vice-versa.
ref: https://www.eevblog.com/forum/testgear/hacking-the-rigol-dho800900-scope/175/RigolTool? I think most people have moved on to the Vendor Bin tool by @zelea2 for upgrading their scope.
BTW: the link that you posted doesn't seem to point to any specific problem.
files in DHO924 dont exist in DHO804:
\data\cal_ext.hex
\FPGA\SPU_H12S1.bit
How do you think, do users of these DHO really need to look at two zeroes after decimal point for vertical scale ranges in V/ (in channel tabs)? Maybe, respected AndyBig will remove them in his modded Sparrow.apk (as he did it for added by him divider ratios) if he'd like?
ps: i want to see again FW differences since my upgrade path (dho804 fw v1.0.0 -> dho924s hacked fw v1.2.2) created bugs thats not exist in legit path (dho924s fw 1.14 -> dho924s fw 1.2.2) as in earlier link, there are files in dho924s dont exist in dho804 such as ...
BTW: The newest RigolTool version I have is 1.0.2 if you need it.
BTW: The newest RigolTool version I have is 1.0.2 if you need it.yes i need it, can you provide the link..? thanks
