Author Topic: Hacking the Rigol DHO800/900 Scope  (Read 1596112 times)
Dimitrius76 and 36 Guests are viewing this topic.
Offline norbert.kiszka
Re: Hacking the Rigol DHO800/900 Scope
« Reply #1875 on: March 01, 2024, 03:39:03 pm »
In my 924S mac address is like completely random (unknown vendor id). First three bytes should be vendor id and Rigol got 0019AF for many years.
https://gist.github.com/aallan/b4bb86db86079509e6159810ae9bd3e4
0019AF Rigol Technologies, Inc.
« Reply #1876 on: March 01, 2024, 03:49:29 pm »
So I did it! The channel widgets in the bottom panel now display the actual probe divider value that was set for the channel.
do we really need the decimal place?
Probably difficulty with cracking compiled binaries - its not super easy to change float into int or the other way round in assembler. Example for ARM64:
https://godbolt.org/#g:!((g:!((g:!((h:codeEditor,i:(filename:'1',fontScale:14,fontUsePx:'0',j:1,lang:c%2B%2B,selection:(endColumn:2,endLineNumber:7,positionColumn:2,positionLineNumber:7,selectionStartColumn:2,selectionStartLineNumber:7,startColumn:2,startLineNumber:7),source:'//+Type+your+code+here,+or+load+an+example.%0Avoid+testFunction(void)+%7B%0A++++float+f%3B%0A++++int+i%3B%0A++++f+%3D+10.0%3B%0A++++i+%3D+(int)f%3B%0A%7D'),l:'5',n:'0',o:'C%2B%2B+source+%231',t:'0')),k:50,l:'4',n:'0',o:'',s:0,t:'0'),(g:!((h:compiler,i:(compiler:arm64g1020,filters:(b:'0',binary:'1',binaryObject:'1',commentOnly:'0',debugCalls:'1',demangle:'0',directives:'0',execute:'1',intel:'0',libraryCode:'0',trim:'1'),flagsViewOpen:'1',fontScale:14,fontUsePx:'0',j:1,lang:c%2B%2B,libs:!(),options:'',overrides:!(),selection:(endColumn:1,endLineNumber:1,positionColumn:1,positionLineNumber:1,selectionStartColumn:1,selectionStartLineNumber:1,startColumn:1,startLineNumber:1),source:1),l:'5',n:'0',o:'+ARM64+gcc+10.2+(Editor+%231)',t:'0')),k:50,l:'4',n:'0',o:'',s:0,t:'0')),l:'2',n:'0',o:'',t:'0')),version:4
The following users thanked this post: AndyBig
Offline AndyBig
  • Country: ru
« Reply #1877 on: March 01, 2024, 03:58:55 pm »
Speaking of it. Another useful thing will be custom probe ratio. Like 11, 12, 13 but I think that probably can be hard. But... In some earlier firmware it was different, In 02.0.02 we have x20 x50 and somewhere before it was only powers of ten - so we can make diffs.
Yes, it will indeed be much more difficult. I'm not even entirely sure that this will be possible without serious modification of the native library.
I simply take the text from the existing list of divisors. I'll look for this list and try to change it. Decimal places do look weird, I agree.
For virtual machine bytecode everything is a little simpler, but you still have to tinker a lot :)
The following users thanked this post: norbert.kiszka
Offline rifkum
« Reply #1878 on: March 01, 2024, 04:01:13 pm »
Very nice work AndyBig!!
But a couple questions/comments...
It appears that you had to increase the bottom channel banner (taking away from the waveform display window?
It also appears this caused the text in the right hand "result" window to not display correctly as you can see "Vmin(C1)" is slightly on top of "Cur:"
Would it be possible to instead keep the bottom ribbon the same size (thus not taking away from the waveform window and causing the above noted problem) and instead
either
Make the large colored channel numbers slightly smaller and move them up and put the 10x under the large channel number?
or
Use the large black space to the right of the 4 channel boxes and put a table of 1,2,3,4 with the associated probe multiplier there?? Or even use the blank space at the top of the window next to Waveform View and put 1:10X, 2:1X, 3:1X, 4:10X
or
find some other open space that the probe multiplier would fit without causing window realestate placement conflicts
It definately seems Rigol could have done a much better job of providing the user with more info (like the missing probe multiplier).
What I really wish is that when viewing the display through the web interface that MORE info could be made available on the external monitor and have a nice large waveform display.
Good work none the less!!!
cheers
Dwight
The following users thanked this post: AndyBig, norbert.kiszka
Offline AndyBig
  • Country: ru
« Reply #1879 on: March 01, 2024, 04:07:56 pm »
Removed decimal places from probe divisor values. At the same time, I fixed the selection of the active channel widget in the bottom panel :)
The following users thanked this post: Mechatrommer, arturmariojr, norbert.kiszka
Offline AndyBig
  • Country: ru
« Reply #1880 on: March 01, 2024, 04:21:13 pm »
No, I didn't change the dimensions of the bottom panel. This misalignment of the text in the results pane is caused by my attempts to compile the measurements into one line. I still haven’t fully figured out the layout of this panel in all its modes, which is why I ended up with such an overlay :( I’ll have to try to figure it out again.
either
By the way, I considered this option for placing the divider, but abandoned it because for this the channel numbers would have to be significantly reduced, and I didn’t want that. But in general, you can try it and see what happens :)
or
No, this place is occupied by LA and AFG widgets in 9xx models .
And here there is very little space when a second window opens, for example with FFT :)
or
Well, this is just the first attempt for now. If a more optimal option is found, of course we can redo it :)
Unfortunately this is not possible :(
« Last Edit: March 01, 2024, 04:37:37 pm by AndyBig »
The following users thanked this post: rifkum
« Reply #1881 on: March 01, 2024, 04:42:07 pm »
In text (char array) its just to set null (\0) to make a flag of end of text. If we need to get rid of ".0" and that is always two chars, then probably easiest way will be to count everything up to null and after that put another null with two places to the left.
If displayed waveform is 100% generated in FPGA (with same resolution as we see right now) then scaling this up will create same pixels but bigger, like resizing existing image.
Anyway, HDMI is a separate display. When I put and run Linux (instead of Android) on sd card, then right now I have only HDMI output. Maybe this info will help with further hacking.
Offline AndyBig
  • Country: ru
« Reply #1882 on: March 01, 2024, 04:46:15 pm »
Everything is easier here :) Here is a piece of code in which the texts needed to be changed:
    new-instance v0, Lcom/rigol/scope/cil/ServiceEnum$ProbeX;
    const-string v9, "Probe_10X"
    const/16 v10, 0xf
    const/16 v11, 0xf
    const-string v12, "10"
    const-string v13, ""
    const-string v14, ""
    move-object v8, v0
    invoke-direct/range {v8 .. v14}, Lcom/rigol/scope/cil/ServiceEnum$ProbeX;-><init>(Ljava/lang/String;IILjava/lang/String;Ljava/lang/String;Ljava/lang/String;)V
    sput-object v0, Lcom/rigol/scope/cil/ServiceEnum$ProbeX;->Probe_10X:Lcom/rigol/scope/cil/ServiceEnum$ProbeX;
    const-string v2, "Probe_15X"
    const/16 v3, 0x10
    const/16 v4, 0x10
    const-string v5, "15"
    const-string v6, ""
    const-string v7, ""
    move-object v1, v0
    invoke-direct/range {v1 .. v7}, Lcom/rigol/scope/cil/ServiceEnum$ProbeX;-><init>(Ljava/lang/String;IILjava/lang/String;Ljava/lang/String;Ljava/lang/String;)V
    sput-object v0, Lcom/rigol/scope/cil/ServiceEnum$ProbeX;->Probe_15X:Lcom/rigol/scope/cil/ServiceEnum$ProbeX;
    const-string v9, "Probe_20X"
    const/16 v10, 0x11
    const/16 v11, 0x11
    const-string v12, "20"
    move-object v8, v0
    sput-object v0, Lcom/rigol/scope/cil/ServiceEnum$ProbeX;->Probe_20X:Lcom/rigol/scope/cil/ServiceEnum$ProbeX;
« Reply #1883 on: March 01, 2024, 04:55:51 pm »
Thats completely unknown language for me. In my case its only C, some script languages and little bit of assembler. Maybe I will start to learn this after I run everything on this scope on Linux instead of Android and that will take some time, because I need not only working kernel but also source or only headers to compile other things. Maybe I will try to run original kernel (binary from Rigol) in the last resort.
Offline AndyBig
  • Country: ru
« Reply #1884 on: March 01, 2024, 04:56:57 pm »
If anyone wants to try, here is a link to the modified application - https://drive.google.com/file/d/1m7_UzTostQTJtiZSkwr4j9gKpi_M7fQ9/view?usp=sharing
Before installation, you need to uninstall the original application:
adb uninstall com.rigol.scopeThen install the new one:
adb install -r Sparrow.apkWithout special steps, the modified application does not have system permissions, so it cannot take screenshots from the Quick button or from the Drive menu. Screenshots can only be taken in web control.
If you need to return the original application, then in the same way, first uninstall the modified one and then install the original one back.
The following users thanked this post: enson72, norbert.kiszka
Offline AndyBig
  • Country: ru
« Reply #1885 on: March 01, 2024, 04:59:34 pm »
Yes, I, too, was not familiar with this language and did not even suspect its existence :) Now I’m studying, I will know another language in addition to those in which I have already written.
« Reply #1886 on: March 01, 2024, 05:03:26 pm »
Unless You will use print screen on USB keyboard.
But tha... replacing all files on running scope (instead of using apk) won't do the trick?
Offline AndyBig
  • Country: ru
« Reply #1887 on: March 01, 2024, 05:08:37 pm »
No, it won't help. The problem is the wrong key with which the application is signed. Only Rigol has the correct key :)
The only thing that will help is copying the files of the installed application in /system/priv-app/ to the folder created there for this application.
« Reply #1888 on: March 01, 2024, 05:14:28 pm »
Or maybe bind quick button to Android print-screen?
Offline AndyBig
  • Country: ru
« Reply #1889 on: March 01, 2024, 05:21:54 pm »
It’s better to copy it to the system directory, and let it work with privileged rights, as intended by the developers :) I’ll need to write a script for this later and run it via adb shell after installation.
« Reply #1890 on: March 01, 2024, 05:37:54 pm »
Now Im little confused. Maybe I miss something or its my lack of Android knowledge. Earlier You told uid 0 wont help as far I remember.
Offline AndyBig
  • Country: ru
« Reply #1891 on: March 01, 2024, 05:53:19 pm »
There are two ways to make an application privileged: 1 - run it as the user android.user.system (this is written in the application manifest during assembly), 2 - place it in the /system/priv-app directory.
The first method is standard, but it is not available to us, because... requires signing the application with a system key. And we can easily use the second one, thanks to Rigol, who left ADB open with root access :)
With the second method, the application is launched on behalf of an ordinary user, but the system still considers him privileged and gives access to those APIs that are inaccessible to a regular application.
« Last Edit: March 01, 2024, 05:55:06 pm by AndyBig »
Offline Randy222
« Reply #1892 on: March 01, 2024, 10:14:00 pm »
@AndyBig, and all others here
Good news, I made your apk take screen shot from the button "Quick"
One sec while I gather up the docs for you. Super easy fix. Nice work on the edits btw.
1sec later...  ;)
My edits are via ssh, I left off using adb to push app back onto scope, I park it in /system/priv-app/Sparrow/ as 644 root:root , pm install that apk
You need to add a perm to AndroidManifest.xml
<uses-permission android:name="android.permission.ACCESS_SURFACE_FLINGER"/>
Recompile, align, sign, reinstall
The launcher should restart scope app in a few sec
Find the uid for com.rigol.scope (ps |grep scope), you'll use this new uid in your platform.xml edit (my example shows u0_a36, your uid might be different)
The pitfall here is, every re-install will get a new uid for the app. I started with u0_a35, my hack failed, I tried again, works. I can create bash script to awk sed the platform file after a app reinstall to make it less pita, etc.
mount -o rw,remount /system
vi /system/etc/permissions/platform.xml
copy-paste the below block in
save file
reboot
<assign-permission name="android.permission.READ_FRAME_BUFFER" uid="u0_a36" />
<assign-permission name="android.permission.CAPTURE_VIDEO_OUTPUT" uid="u0_a36" />
<assign-permission name="android.permission.CAPTURE_SECURE_VIDEO_OUTPUT" uid="u0_a36" />
<assign-permission name="android.permission.ACCESS_SURFACE_FLINGER" uid="u0_a36" />
<permission name="android.permission.READ_FRAME_BUFFER" >
        <group gid="u0_a36" />
    </permission>
<permission name="android.permission.CAPTURE_VIDEO_OUTPUT" >
    </permission>
<permission name="android.permission.CAPTURE_SECURE_VIDEO_OUTPUT" >
    </permission>
<permission name="android.permission.ACCESS_SURFACE_FLINGER" >
    </permission>
side note for readers, if you want to see what all the code is logging, from ssh just run "logcat /system/log", then touch a knob, or tap screen and see what coords you actually touched. When logcat is idle, you can hit enter a few times to make a space, then touch a scope control, everything is basically logged, which in my opinion we might want to turn off to take some load off the cpu side, not need to log all that stuff unless we trying to debug it.
And sorry I could not hack it as fast as AndyBig has, my dho has been in the box, I only get to play around with it in limited spare time, I actually reworking my little lab area.
« Last Edit: March 01, 2024, 10:41:55 pm by Randy222 »
Offline gabiz_ro
« Reply #1893 on: March 01, 2024, 10:45:25 pm »
Those system key, where we can find them?
We have full raw dump of sdcard.
I don't know about cryptography but how system verify signature only with public key?
« Reply #1894 on: March 01, 2024, 10:50:11 pm »
I think Im no expert in cryptography, but when You generate private and public key, then private key You keep in a secret and its used only to sign other staff, including other keys. Public key is only to verify signed files, that's why its public.
Offline Randy222
« Reply #1895 on: March 01, 2024, 10:53:40 pm »
x509 cert signing, that's how.
I will have to say, if verification process needs to run through memory (which it does), then as root you have a way to steal key data. Is it worth the effort? Not for this device.
Offline AndyBig
  • Country: ru
« Reply #1896 on: March 02, 2024, 05:50:11 am »
The public/private key scheme works a little differently. In order to verify a signature with a private key, you only need to know the corresponding public key. This is from the field of asymmetric encryption, where encoding is done with one key from the pair, and decoding is done with the second key. Thus, the system does not need to store the private key, it only needs to know the public key. Therefore, trying to find the private key in the firmware is pointless, it simply isn’t there :)
Offline AndyBig
  • Country: ru
« Reply #1897 on: March 02, 2024, 05:54:57 am »
Great, then there is another method for granting high privileges to an application :)
I think that the issue with different uids can be solved by specifying some specific user in the application manifest, but I have not tried this yet.
Offline AndyBig
  • Country: ru
« Reply #1898 on: March 02, 2024, 01:37:39 pm »
Today I wrote and tested scripts to automate the installation of a modified application and grant it privileged rights so that it could take screenshots :)
The archive contains the application itself, as well as two .bat files, a .sh script and a readme. If for some reason it is not possible to run .bat files, then the readme describes all the steps using adb commands to install the application, grant it privileged rights and return to the original application.
The spmod_inst.bat file is used for the initial installation of the modified application and for updating it.
The spmod_uninst.bat file is used to return to the original application after the modified one.
The sysmode.sh file is a script that is copied to the oscilloscope and executed there, it includes all the actions to escalate application privileges.
Archive link - https://drive.google.com/file/d/15znLDczPyQCcPbygPwo7iK6uTHG0mk7z/view?usp=sharing
The following users thanked this post: sonic, skench, RAPo, Randy222, norbert.kiszka
Offline Randy222
« Reply #1899 on: March 02, 2024, 04:27:25 pm »
Check the other apps in priv-app, are they 644 and not 755? I forget, check it.
Also, that's a lot of scripting,
Take a look at managing user UID with pm.
Example,
before install add a uid using pm without restrictions
then install using pm and the -user switch
If that works a-ok, then you only need to echo into the platform.xml file once, and from there just re-use same uid during a re-intsall of the app.
I'll write up a .sh to install the app,.................  uninstall app, create uid , echo into the xml, install app.  But not until mon or tue next week. something like "install.sh [uid] [apk]"
creates the uid, install app, fixes platform.xml, it will also check to see if the install is first time or a reinstall.
priv-app alone does not allow surface flinger for non-system uid. is there a fix just in manifest?
Also to note, we can do this perms thing only because it's an old version of droid, this feature has been deprecated, newer droid REQUIRES system uid to get at surface flinger.
That's not the point. The pub key is held in a trusted/protected area, just as they are when using keys auth for ssh, there's no priavte key on the system right, but it verifies only with a "trusted" pub key. The goal would be to find out how to add your pub key to the system keystore, and memory hacking is a way to do that. Once you can add your pub key to that protected keystore, then anything you sign with your private key will be trusted by the system.
« Last Edit: March 02, 2024, 04:41:13 pm by Randy222 »
The following users thanked this post: AndyBig, RAPo, norbert.kiszka
