achievement like this is already great, if its only involves flipping a constant bit/byte without changing code size/structure/logic. but even greater if it involved adding more codes into the compiled apk.. it might not be easy, you probably need access to android/java documentation on how to assemble into a machine/OS readable format, by paying professional fee... i dont know this android SDK/assembler stuffs.. maybe you need to investigate rat/grey/black/illegit route, just an idea
so ymmv.
The decompiled source codes of DALVIK allow you to add/remove/change anything you like. These are not machine codes in an executable file, where you need to take care not to break the structure of the file, where it is impossible to insert something, or replace it with something larger. No, here are the source codes in a programming language, just a very low-level one
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
Here is an example of a piece of such source code:
# virtual methods
.method public draw(Landroid/graphics/Canvas;)V
.locals 16
move-object/from16 v0, p0
.line 85
iget-object v1, v0, Lcom/rigol/scope/views/resultItem/ResultItemDrawable;->mBounds:Landroid/graphics/Rect;
iget v1, v1, Landroid/graphics/Rect;->right:I
iget-object v2, v0, Lcom/rigol/scope/views/resultItem/ResultItemDrawable;->mBounds:Landroid/graphics/Rect;
iget v2, v2, Landroid/graphics/Rect;->right:I
iget v3, v0, Lcom/rigol/scope/views/resultItem/ResultItemDrawable;->mTopWidth:I
# changed
# const/16 v3, 120
# sub-int/2addr v2, v3
# sub-int/2addr v1, v2
.line 87
iget v2, v0, Lcom/rigol/scope/views/resultItem/ResultItemDrawable;->currentState:I
if-eqz v2, :cond_1
const/4 v3, 0x1
if-eq v2, v3, :cond_0
goto/16 :goto_0
.line 92
:cond_0
iget v2, v2, Landroid/graphics/Rect;->left:I
int-to-float v5, v2
const/4 v6, 0x0
int-to-float v7, v1
iget v2, v2, Landroid/graphics/Rect;->bottom:I
int-to-float v8, v2
iget v2, v0, Lcom/rigol/scope/views/resultItem/ResultItemDrawable;->mRadius:I
add-int/lit8 v4, v2, 0x1
int-to-float v9, v4
# const/high16 v9, 0x3f000000 # 0.5f
add-int/2addr v2, v3
int-to-float v10, v2
# const/high16 v10, 0x3f000000 # 0.5f
iget-object v11, v0, Lcom/rigol/scope/views/resultItem/ResultItemDrawable;->selectedPaint:Landroid/graphics/Paint;
move-object/from16 v4, p1
invoke-virtual/range {v4 .. v11}, Landroid/graphics/Canvas;->drawRoundRect(FFFFFFLandroid/graphics/Paint;)V
.line 96
You can change it as you like, when you reassemble it, it will be compiled into the correct “executable” Java file with all the changes made.
the problem is when new FW update is released, are you patient enough to redo all the hardwork again? maybe building an automating app can help significantly? just an idea ymmv. cheers.
Well, I try to mark all changes with a comment so that later they can be easily found in all files. In addition, I think that during updates a very small part of the code will be affected, so you can simply copy the files with your changes.
In general, just for fun, you should try to decompile versions 00.01.01 and 00.01.02 and compare the resulting sources
Currently Im porting Linux kernel to regular Debian on this scope. Rigol added some of their Linux modules.
I assure you that changing the binary firmware of such an FPGA is several orders of magnitude more difficult than any port of the Linux kernel
Perhaps this can be compared to completely rewriting the entire kernel from scratch. Moreover, initially without having any source codes for this kernel, only a compiled kernel and a disassembler
