Author Topic: Hacking the Rigol DHO800/900 Scope  (Read 1625716 times)
Vovas and 22 Guests are viewing this topic.
Offline AndyBig
  • Country: ru
Re: Hacking the Rigol DHO800/900 Scope
« Reply #1600 on: February 23, 2024, 05:51:47 am »
So is it extremely difficult to do these UI mods, and have you discovered any other defects like the screenshots not functioning?
I can't evaluate it objectively. For me - yes, it’s difficult, because... I'm not familiar with Android development, I don't know the basics of Android applications - how they work, how they interact with the OS, how they generate images, etc. I have to google a lot, guess a lot, and in some cases try to act at random and see what happens :) In addition, I have to change low-level code - DALVIK, which also does not add convenience. I can imagine that for a person who is well acquainted with developing applications for Android, this will all be much easier :)
IF the label and value was all on one line, it could be smaller.  But would we see enough digits to still be useable?
Yes, I thought about this too, but the names of some dimensions are too long for all the numbers to fit after them. Although in principle you can expand the entire panel :)
The following users thanked this post: AceyTech
Offline jsobell
« Reply #1601 on: February 23, 2024, 06:02:16 am »
Side note:  If you care, you might try peeling up the label on the defective fan and look for cold solder joints on the SOT part(s).  There's often a hall effect sensor & FETs under there.
Yes, I did that, and I reflowed the pads I could see, but most is under the plastic. Still no luck.
J.
Offline AndyBig
  • Country: ru
« Reply #1602 on: February 23, 2024, 06:46:56 am »
A convenient application for unpacking and decompiling .apk https://github.com/skylot/jadx . It can even work as a debugger, I tried it and it works :)
The following users thanked this post: Mechatrommer, AceyTech
Offline RAPo
« Reply #1603 on: February 23, 2024, 08:40:25 am »
But could we omit the names and only show (a scaled down) icon together with the value on one line?
And for the next wish: make it a setting we can change somewhere using the UI ;-)
Offline Fungus
« Reply #1604 on: February 23, 2024, 09:12:48 am »
It seems to me that only the lazy have not yet scolded the way Rigol shows measurements :)) And quite deservedly, I think.
I have.
It's especially criminal how the stat values are split across two lines:
The DHO1000 does it like this:
The firmware is supposedly the same, I wonder if we can get the DHO800 to do it like the DHO1000.
Offline RAPo
« Reply #1605 on: February 23, 2024, 09:21:51 am »
I would love to have the statistics/measurements in a window that can be moved along the screen.
Offline AndyBig
  • Country: ru
« Reply #1606 on: February 23, 2024, 09:31:56 am »
Icons that are one line of text high will simply not be legible on the screen.
You think too well of my ability to modify the application :))))
The following users thanked this post: RAPo
Offline AndyBig
  • Country: ru
« Reply #1607 on: February 23, 2024, 09:33:48 am »
This is very interesting. You need to get the application from DHO1000 and see how it is done there.
Online ebastler
« Reply #1608 on: February 23, 2024, 09:48:15 am »
Should all be nicely laid out in the .GEL files which Rigol offers for download, shouldn't it? I certainly appreciate their open format for the firmware update files.  :)
Offline RAPo
« Reply #1609 on: February 23, 2024, 10:01:58 am »
Maybe I didn't express myself quite right, but if you take the current icon height (so the same viewing as we are used to) and place the values next to it, it can work.
See the image
Remember Pipi Longstocking: “I have never tried that before, so I think I should definitely be able to do that.”  :-DD
Online ebastler
« Reply #1610 on: February 23, 2024, 10:06:51 am »
I don't think the icons alone are sufficiently self-explanatory to distinguish all the different measurement flavors.
Offline AndyBig
  • Country: ru
« Reply #1611 on: February 23, 2024, 10:14:21 am »
See the image (Attachment Link)
Well, at a quick glance, try to distinguish these two icons from each other from your picture on a rather small oscilloscope screen, and also remember which icon means what :)
Offline shapirus
  • Country: ua
« Reply #1612 on: February 23, 2024, 10:15:09 am »
Well, it almost worked :) You just need to correct the drawing of the border around the dimension :)
Very promising! Hope this will eventually boil down to a recipe suitable for a regular (advanced) user.
Offline gabiz_ro
« Reply #1613 on: February 23, 2024, 10:18:33 am »
Maybe negligent software developer by mistake replace tab with new line
Offline RAPo
« Reply #1614 on: February 23, 2024, 10:19:58 am »
If you look at the measurement dialogs, Rigol has supplied a different icon for each type of measurement.
You need the information on which channel(s) the measurement takes place.
That can be done by attaching the coloured text as shown in my image.
Or, if we would be really fancy, place the icon in a bar with the same colour as the channels.
Offline shapirus
  • Country: ua
« Reply #1615 on: February 23, 2024, 10:22:38 am »
Perhaps taking enclosed ball-bearing fans and chopping them is a better way to go? 40mm is not ideal, but as it works effectively and is so much quieter...
I doubt that such a big difference in the loudness can be attributed to the ball bearing vs sleeve (or whatever) difference. Both create almost zero noise on their own, unless broken.
There must be something else -- the number of blades, their angle, and, very likely, the very difference between the 40 mm and 45 mm diameter, where the latter leaves much less space between the edges of the blades and the fins of the heat sink, possibly resulting in the air siren effect.
Online ebastler
« Reply #1616 on: February 23, 2024, 10:24:52 am »
Sure. But I would not be willing to memorize the subtle details to distinguish them all, and recall which one means which. And, when in use, stare at them long enough to actually see all the little details.
Offline RAPo
« Reply #1617 on: February 23, 2024, 10:25:44 am »
with a bit of practise that is not too hard. Rigol did a good job on the icons, and if you add a measurement, you'll see the corresponding icon.
Offline shapirus
  • Country: ua
« Reply #1618 on: February 23, 2024, 10:26:30 am »
Right, but they are so small and also drawn in gray over dark background, that they become useless unless you look at them up close. It also takes time and effort to distinguish one from another, they all look too similar.
Text is just so much better -- it is read and recognized at a glance, can be read from a (much) larger distance.
Online ebastler
« Reply #1619 on: February 23, 2024, 10:27:55 am »
Good luck distinguishing Vmax, Vtop, Vamp and Vpp, to pick just one example.  :P
Offline shapirus
  • Country: ua
« Reply #1620 on: February 23, 2024, 10:28:28 am »
There's no way one can realistically tell these three apart from 60 cm, let alone remember which means what:
Text labels, on the other hand, are readable and immediately obvious.
« Last Edit: February 23, 2024, 10:30:31 am by shapirus »
The following users thanked this post: ebastler, Jacon, AndyBig, mwb1100
Offline AndyBig
  • Country: ru
« Reply #1621 on: February 23, 2024, 10:29:14 am »
The icons, of course, are different, and they generally indicate what they mean. But the differences are so insignificant and hard to see with a small icon size that you have to look closely to understand which icon is drawn on this dark gray background :)
Offline AndyBig
  • Country: ru
« Reply #1622 on: February 23, 2024, 10:34:53 am »
Yes, you just need to uninstall the native application and install the modified one. All this is easily done through ADB :) But the ability to take screenshots on an oscilloscope is lost; this can only be done through web control.
No, it's more complicated than that. Partially specified through layouts in .xml, partially defined in source codes. It’s difficult for me to understand all these intricate interweavings of the structure of the Android application.
Offline RAPo
« Reply #1623 on: February 23, 2024, 10:35:19 am »
(Attachment Link)
60 cm is a bit much, but on the web interface, I can clearly see the differences.
And as I said, it takes a bit of practice, but I really think Rigol has done a good job.
But as asked before: maybe it should be configurable in a settings dialog.
Offline RAPo
« Reply #1624 on: February 23, 2024, 10:38:21 am »
Maybe I have eagle eyes, but I can easily do that.
