You don’t just need to unzip and then archive, you need to decompile and then compile back, and this is more difficult ![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
At it's most elemental level, patching does not require decompilation and recompilation. Certainly when it's possible to get compilable source code from a binary distribution, such as when Java archives include the original source, that's great but it's pretty rare. When you can get an approximation of original source through decompilation with tools such as Ghidra or IDA, it's not so that it can be recompiled, but only to help follow the code in a higher level language than assembler. But in most cases you're disassembling to assembler code and reading that to understand what the code is doing, therefore strong knowledge of assembler is necessary for effective RE.
Sometimes just following the logic is enough to understand the algorithm in order to create a key generator, in which case no patching or updating the binary is required. Otherwise, patching data or opcode bytes directly in the binary (e.g. to jump over a validation check) is done to alter or short-circuit the logic to achieve your goal. There is no compiling of source code happening here.
I did a great deal of software reverse engineering back in the 90's and early 00's in both personal and professional contexts, leveraging tools like Periscope and SoftICE as well as IDA, OllyDbg, and others to RE and patch code. It was generally easier back then before methods like encryption, signing, anti-debug tricks, etc. were commonly employed that made RE more difficult, though seldom impossible.
