I've simplified the procedure and compiled the generator for ARM64.
All you need to do now is transfer the executable generate_all_options to the scope in /rigol/data and run it from there.
It will create all the option.lic files which will be installed after reboot. No need to use SCPI commands anymore.
The COMP/EMBD/AUTO options are all related to protocol decoding and they show in the About/Options screen.
I can confirm that this works on DHO804.
BW is reported as 100M now (in Utility/About), 50Mpts is now available too.
For some reason however I don't see them as options in Utility/Options:
![Hacking the Rigol DHO800/900 Scope](https://www.eevblog.com/forum/index.php?action=dlattach;topic=393928.0;attach=2008418;image)
They weren't there before generating the licenses, either. The only difference on this screen is that the second option changed from "limited" to "forever".
Rise time that I'm testing with my pulse generator based on CD74AC00E (5Vpp) has also improved: 2.8ns before, 2.4ns now -- as measured by the scope's own measurement function. I don't know if it measures it correctly -- if I use cursors and set the starting point at where the signal is just starting to rise, then it'll be over 3ns. I don't know what is the right way to measure it, i.e., at which levels relative to low and high states. Also this IC is far from being the fastest, so I don't really know at which point I'm hitting its actual rise time and not the scope's limitation (however I definitely hit the latter at the stock 70MHz BW).
Now I want to turn the scope into a DHO924 and see what happens.
Update: yes it works just fine, using zelea2's vendor.bin utility. Change model, regenerate option licenses, done. Really appreciate the work of everyone who put their time and effort into R&D. Rise time is now ~2.2ns, and now I believe this is the IC's actual performance, so of course now I need to build a faster pulse generator :).
p.s. at first glance, no self-calibration is required after all this: no DC offset, voltage readings also look good.
