Author Topic: Hacking the Rigol DHO800/900 Scope  (Read 1625773 times)
0 Members and 23 Guests are viewing this topic.
Offline alrox
Re: Hacking the Rigol DHO800/900 Scope
« Reply #1175 on: February 04, 2024, 09:44:41 pm »
Thank you so much for a speedy and informative guide, I will certainly try it in next few hours.
Also to others pointing out to me my lack of understanding of the Rigol operating system foibles.
I thank you once more.
Offline alrox
« Reply #1176 on: February 04, 2024, 11:57:38 pm »
I have tried this now and it works perfectly for me, thank you zelea2. There are a few got-yers for people not proficient in how some of the supporting software works (no disrespect zelea2) and maybe not used to using command line ( I know most on the thread will say - in that case should not be here), but that's disingenuous. Most newbies want to learn and get advice from those more learned than they are.
If enough people with limited knowledge are struggling (post a request- if many) then I will try to do a fully detailed step-by-step for the totally inept newbies like me, when it comes to this scope's architecture, to get the job done.
The following users thanked this post: AceyTech, Silver_Is_Money
Offline AceyTech
« Reply #1177 on: February 05, 2024, 09:30:36 am »
Good job! That was nice of @zelea2 to fire off a list for ya. -Amazing and talented person.
Sadly, despite best intentions, there are sometimes assumptions in the step by step guides that we, the uninitiated, have to figure out on our own.  That's great that you were able to get up and running. Kudos!  Proof that you DO belong here.
There's a very important post by Dave/EEVblog in the beginning of this Test Equipment thread that says "Regulars. please be nice to newbies who ask a question..."
  It's actually regarding searching, but it's good for everyone to remember that "we were all newbies once".
« Last Edit: February 07, 2024, 09:48:49 pm by AceyTech »
The following users thanked this post: RAPo, cte
Offline Randy222
« Reply #1178 on: February 05, 2024, 02:17:54 pm »
So now that the options are back with 00.01.02.00.02, question now is, do I actually upgrade to that version?
Will post a question in the Bugs + Firmware thread to try and get what the new bugs are, and if any were fixed.
Offline shapirus
  • Country: ua
« Reply #1179 on: February 05, 2024, 02:50:46 pm »
Another question is what is actually better for, say, an 804 scope: activate all the 8xx options (i.e., 100, or what was it, 125 MHz bandwidth), or install the 900 firmware, which unlocks, IIRC, 200 MHz bandwidth. The question is, are those 200 MHz actually real, or, in other words, are they usable given the 1.25 Gsa/s max rate?
Offline axantas
« Reply #1180 on: February 05, 2024, 04:06:37 pm »
As you are not drilling a hole into your machine and the option is revertable: go for the max. Other option: A 1:1 comparable setup on a 900 and a maxed out 800. Could we use the Batronix Demo Board for that? Third option: wait for the profs, who already tested that. There might be a difference regarding the non populated memory chip sockets on the 800 - but the 1.25Gsa/s is valid for both.
Offline Randy222
« Reply #1181 on: February 05, 2024, 04:09:02 pm »
I made my 804 a 914, then added just a couple of options.
IIRC, someone said the bandwidth was good for 180MHz -3db.
I think you have to look at the actual hardware diffs between 800-900 series to understand how options work. IIRC, less the digi of 914-924S, less the sig gen, all the same hardware. (or something like that).
« Last Edit: February 05, 2024, 04:50:54 pm by Randy222 »
Offline Aleksandr
  • Country: ru
« Reply #1182 on: February 05, 2024, 04:16:51 pm »
Is there a complete list of options and a description of what they do (what are they for)?
Offline Randy222
« Reply #1183 on: February 05, 2024, 04:45:08 pm »
There are some posts about options.
I am not 100% of what they all do.
This list is from the gen tool for 900 vendor.bin
Is the list for the 800 vendor.bin longer? I am not sure, but you can perhaps do that diff using the gen tool. Make an options list for 800 and 900, then compare them.
Some did apply, some did not. My 804 has a 914 vendor.bin
DHO900-AERO
DHO900-ARINC
DHO900-AUDIO
DHO900-AUTO
DHO900-BND
DHO900-BODE
DHO900-BW100T20
DHO900-BW10T20
DHO900-BW15T25
DHO900-BW2T42
DHO900-BW2T8
DHO900-BW4T8
DHO900-BW7T15
DHO900-BW7T20
DHO900-CM_ENET
DHO900-CM_HDMI
DHO900-CM_MIPI
DHO900-CM_USB
DHO900-COMP
DHO900-COUNT
DHO900-DG
DHO900-EMBD
DHO900-EYE
DHO900-FLEX
DHO900-MSO
DHO900-PWR
DHO900-RLU
DHO900-RTSA
DHO900-UPA
Offline Fungus
« Reply #1184 on: February 05, 2024, 04:50:38 pm »
I say activate all the 804 options. That's 200Mhz real (measured+confirmed) bandwidth even though it only says 100Mhz, and 50M memory.
Yes it's real, up to 280MHz if you change it to a DHO924, but ... do you want that given the sample rate?
200MHz seems more sensible to me. 200MHz lets you use two channels without aliasing.
The following users thanked this post: shapirus, AceyTech
Offline Randy222
« Reply #1185 on: February 05, 2024, 05:21:23 pm »
But if you swap vendor.bin, then only some options apply. I find it easier to swap vendor.bin and then apply a few options.
« Last Edit: February 05, 2024, 05:45:52 pm by Randy222 »
Offline Fungus
« Reply #1186 on: February 05, 2024, 06:09:05 pm »
There's only two options that do anything - bandwidth upgrade and 50M memory.
If you make it a DHO900 then you already get both of those.
If you want to apply them to a DHO804 then you don't need to touch vendor.bin
Offline shapirus
  • Country: ua
« Reply #1187 on: February 05, 2024, 07:39:42 pm »
...and if I leave only one channel on? Will the higher BW be of any use? For those special occasions, you know, when one needs to grab a bottle of beer, sit in a comfortable chair and watch the sharp rise and fall edges.
Offline Fungus
« Reply #1188 on: February 05, 2024, 08:29:23 pm »
It's not really much more bandwidth. You'd have to go to 400Mhz to halve the rise time.
Even so, you can switch to another model in about 10 seconds for those "special occasions". Just send a different vendor.bin then kill the 'scope task. It will auto-restart after a few seconds as the new model. You can even make a .bat file to do it.  :)
Offline Randy222
« Reply #1189 on: February 05, 2024, 08:52:15 pm »
Bode lic took on a 914 vendor.bin
If you just swap vendor.bin to a 914, you get more BW right there, hence in the 804 you need to apply an option, so less option setting if you swap the vendor.bin, etc.
Offline zelea2
« Reply #1190 on: February 05, 2024, 09:10:01 pm »
I have further analyzed the firmware and I've created a list with all available options for each series:
rigol_vendor_bin -l
Available options for Series: 800 900
 0 BND                          0
 2 COMP                         5
 3 EMBD                         3
 4 AUTO                         4
19 RLU                          1
20 BODE                         .
21 BW7T10                       2
25 BW15T25                      .
Bandwidth 'StaticSysBand' range [4-17] depending on options and hardware:
4 (default), 5 (21,23), 6 (21-hw4-5,23-hw4-5,24), 7 (25 series 900)
This library also covers Rigol series 1000 and 4000 on top of 800 and 900 so not all the options are available.
First option BND stands for bundle and it is activated by default and covers the basic options for each series.
I only enable RLU and BW7T10 for my DHO804
The bandwidth is just a number from 4 to 17 (only 8 cases) - probably sent to the FPGA - and only certain hardware allow some of these higher numbers.
« Last Edit: February 05, 2024, 09:45:43 pm by zelea2 »
The following users thanked this post: thm_w, skench, AceyTech
Offline Fungus
« Reply #1191 on: February 05, 2024, 10:22:18 pm »
Can you enable CAN/LIN on DHO800?
Offline Randy222
« Reply #1192 on: February 05, 2024, 10:49:51 pm »
rigol_vendor_bin -l
 0 BND                          0
 2 COMP                         5
 3 EMBD                         3
 4 AUTO                         4
19 RLU                          1
20 BODE                         .
21 BW7T10                       2
25 BW15T25                      .
In last iteration of the gen tool (I guess for Key.data FW's), it only gave me one Comp, but nine BW options for 914 vendor.bin.
Now you show in chart four Comp options for 900 series?
Am I reading the chart correct? The numbers under series means how many options there are for that type of option (COMP, AUTO, etc etc).
« Last Edit: February 05, 2024, 10:51:42 pm by Randy222 »
The following users thanked this post: K5HJ
Offline zelea2
« Reply #1193 on: February 06, 2024, 12:18:27 am »
The numbers are just what the scope uses to identify the options. If the option is not available it's a dot, otherwise it's this number.
I've removed all options for the 1000 and 4000 series. Use the -l option if you want to see the entire list.
« Last Edit: February 06, 2024, 12:40:45 am by zelea2 »
Offline zelea2
« Reply #1194 on: February 06, 2024, 12:39:18 am »
From what I've disassembled I think the answer is no but I might be wrong.
One thing that I couldn't figure out is what are the default bundle options for each series and that's something I looked long time for but it's well hidden in that C++ code.
I don't really understand what's the attraction of a L.A. on this scope. You usually want your L.A. to be integrated with your computer as tightly as possible and a scope's
not good for this. I have several L.A. at home and at work but the one that I'm using most often is this: https://www.dreamsourcelab.com/product/dslogic-series/
It can sample 16ch@400MHz has all the possible decoders and you can even write your own decoders and it's only 150$. You can dump all the waveforms as .vcd files
and load them in powerful processing software on your PC. One of the best features is RLE encoding for signals with few transitions and you can record hours of transactions.
Or you can go even cheaper at 10$ https://www.aliexpress.com/item/1005003649856071.html and that still covers half of your typical L.A. captures.
Although I have a 10k$ Tektronics L.A. at work I rarely use it.
For CAN sniffing / probing what I found best was any STM32 part with a CAN driver and a USB interface. That makes a very powerful development environment.
I even have a board with an STM32 + FPGA  so I can watch for certain CAN messages in real time and knock them off before they even finish and replace them with my own ones.
« Last Edit: February 06, 2024, 12:49:32 am by zelea2 »
The following users thanked this post: thm_w, skench, AndyBig, cte, AceyTech
Offline AceyTech
« Reply #1195 on: February 06, 2024, 04:31:20 am »
+1 for DreamSourceLab gear.  Their UI and software design is top notch.
I really wanted to do the Logic Analyzer upgrade hack to my DHO, but the more I looked into it, the less appealing it became.
« Last Edit: February 06, 2024, 09:57:54 am by AceyTech »
Offline Fungus
« Reply #1196 on: February 06, 2024, 05:50:58 am »
That's what I thought.
It's the RS232/SPI/I2C decoders.
Offline MalikovVV
  • Country: by
« Reply #1197 on: February 06, 2024, 07:52:51 am »
On my DHO-812, after updating to version 1.0.2, a CAN trigger appeared (without LIN), but with restrictions (Limited), after activating the AUTO option it switched to Forever.
It turns out that Rigol included the AUTO option as a bonus for buyers of DHO-812 and 814?
The following users thanked this post: thm_w, AceyTech
Offline AndyBig
  • Country: ru
« Reply #1198 on: February 06, 2024, 09:17:14 am »
Agree. I think that LA on an oscilloscope is not serious. You can quickly look at a short data packet, but for normal analysis and debugging of protocols you still need a normal separate LA connected to a computer.
Online ebastler
« Reply #1199 on: February 06, 2024, 10:20:22 am »
I think the main attraction is the support for mixed signal analysis: Observe an analog signal which is measured or controlled and at the same time watch the digital control signals; observe a large number of digital channels and check whether the suspicious behaviour of some channels is due to bad signal quality, etc.
Yes, you can do that by keeping two separate devices in sync, but it is more convenient to use an integrated MSO. For purely digital analysis, a PC-based logic analyser will have many advantages -- memory size, data management, choice of decoders, screen resolution, ...
« Last Edit: February 06, 2024, 10:29:35 am by ebastler »
