Can you enable CAN/LIN on DHO800?
From what I've disassembled I think the answer is
no but I might be wrong.
One thing that I couldn't figure out is what are the default bundle options for each series and that's something I looked long time for but it's well hidden in that C++ code.
I don't really understand what's the attraction of a L.A. on this scope. You usually want your L.A. to be integrated with your computer as tightly as possible and a scope's
not good for this. I have several L.A. at home and at work but the one that I'm using most often is this:
https://www.dreamsourcelab.com/product/dslogic-series/It can sample 16ch@400MHz has all the possible decoders and you can even write your own decoders and it's only 150$. You can dump all the waveforms as .vcd files
and load them in powerful processing software on your PC. One of the best features is RLE encoding for signals with few transitions and you can record hours of transactions.
Or you can go even cheaper at 10$
https://www.aliexpress.com/item/1005003649856071.html and that still covers half of your typical L.A. captures.
Although I have a 10k$ Tektronics L.A. at work I rarely use it.
For CAN sniffing / probing what I found best was any STM32 part with a CAN driver and a USB interface. That makes a very powerful development environment.
I even have a board with an STM32 + FPGA so I can watch for certain CAN messages in real time and knock them off before they even finish and replace them with my own ones.
