DHO bloat, not needed, at least from my testing, scope runs a-ok after disabling stuff.
The default build only has the Android Demo package disabled, but we can disable more.
Disabling does appear to be boot persistent (can likely ditch printspooler) NOTE: proxyhandler seems to be needed for wifi connection to work.
I'm all for debloating to speed up the boot time. Drives me nuts! waiting for a piece of test gear to boot.
But, can you ditch the printspooler service and still print? I think I saw someone printing from his scope last week.
In the start script, they sleep 10 after booting FPGA, guessing it needs some time to boot, and needs to be up before all the gpio driver stuff happens.
After the touchscreen driver is loaded (kinda last bit of loading devices/drivers in script) I have to do a sleep 15 before sending scpi commands. It appears the rigol packages takes some time to fully load up. If you send scpi too soon they either don't apply or the scope app crashes.
My boot time testing results:
45sec for scope to boot where it enters Run state (no screen yet)
+4sec (49) to have scope screen w/ touch
+2sec (51) for the scpi commands to take effect
So, I believe initial test/teardown boot tests were around 58sec boot. Now I have it to 49sec. 9sec faster.
Noted, this is with short list of packages disabled, and I also have in my start script an added line to insmod the 8188eu.ko wifi driver.
