New update for the RT 8188eu v3.6 nano wifi
From my testing, it appears that when you attempt to insert the nano after the DHO is running, the 8188eu.ko KLM fails to load in.
If you boot with the nano in USB port, the system loads the 8188eu.ko KLM.
I fix this issue by doing an insmod in the "/rigol/shell/start_rigol_app.sh" script
I added the following just after the section (near top) where it loads the Motorcomm ETH KLM
insmod /system/lib/modules.8188eu.ko
Now I can insert the nano after boot time and there's no issue of the wifi coming up.
The system should just do a insmod of the ko KLM when it recoginizes that device being inserted into USB port, and then do a rmmod to pull the KLM out when the nano gets pulled from USB port.
That said, most will just leave the wifi nano in the USB port, so it's always there at boot. However, some like me have a USB hub in USB-A port, and the hub has ports that have on/off switches. I don't always have the nano wifi up and running, I turn it on when needed, etc.
Update: another odd thing. You have to insert the nano and manually turn on the wifi slider (android). Leave the slider as is (on position), now the wifi goes on/off in sync with presence of the nano. However, if you manually have the slider to off, the insertion of the nano will not turn on the wifi. That's some odd functionality.
Sorry for taking so long, here's what I got:
rk3399_rigol:/ # dmesg
rk3399_rigol:/ # lsusb
Bus 003 Device 001: ID 1d6b:0002
Bus 004 Device 001: ID 1d6b:0003
Bus 003 Device 002: ID 0bda:8179
[ 271.381320] usb 3-1: new high-speed USB device number 2 using xhci-hcd
[ 271.500329] usb 3-1: New USB device found, idVendor=0bda, idProduct=8179
[ 271.500409] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 271.500424] usb 3-1: Product: 802.11n NIC
[ 271.500437] usb 3-1: Manufacturer: Realtek
[ 271.500461] usb 3-1: SerialNumber: 00E04C0001
[ 271.753363] SELinux: Unable to set superblock options before the security server is initialized
I then tried your insmod command (although you had a typ-o, should be /system/lib/modules/8188eu.ko), it now seems to be mostly working:
I booted several times in a row. First two worked great. Third time it still worked, but seemed a bit slower to start. I also tried unplugging and plugging it back in and this didn't seem to work. Fourth time, I plugged in the hub and keyboard along with the WiFi dongle and it didn't seem to work. Fifth and sixth times I went back to just WiFi, and it worked but was a bit slow to start. Then I unplugged and plugged back in, and that worked. Repeated a few times. All good. Then tried a 7th time with the hub, and it still worked.
So weird that mine is behaving so differently from other people's... Should I edit the file /rigol/shell/start_rigol_app.sh and add the insmod command in there? How do I edit it? vi?
