I watched both of Retrochannel's videos, and first updated to the 01.01 firmware, and applied the bandwidth/sample depth hack by connecting the scope directly to my router via Ethernet. Everything seemed to work fine. I then ordered a USB WiFi adapter and tried to set that up and noticed a lot of... flaky behavior.
When I first tried, the touch screen didn't work with the keyboard plugged in. Since then, it hasn't been an issue. However, on about 1 in 5 bootups with the WiFi dongle installed, I will get "LAN Disconnected" and everything works fine. The other 4 out of 5 times, it seems to just ignore the dongle. I don't think I ever saw an instance of disconnecting and reconnecting the dongle fixing the issue. If you reboot enough, it will eventually work, but it seems pretty random. When it's not working, attempts to turn on WiFi don't work. It'll go on for a split second and then disable. I'm thinking I just got lucky the first time when I went to go set everything up.
Anyone got any ideas? I apologize if this was discussed earlier and I missed it.
