Hmm, the sequential numbers in the entries seem to correspond to the vertical scale adjustment steps in fine mode.
Numbers: 100000,102000,104000,...,198000,200000,205000,210000,215000,...,495000,500000,510000,520000,530000,...,980000,990000,1000000,1 020000,1040000 and so on up to 10000000000, that is, 5 circles with a zero added to the end after each circle.
Increasing the voltage scale in fine mode:
1.00mv,1.02mv,1.04mv,...,1.98mv,2.00mv,2.05mv,2.10mv,2.15mv,...,4.95mv,5.00mv,5.10mv,5.20mv,5.30mv,... ,9.80mv,9.90mv,10.00mv,10.20mv,10.40mv and so on up to 10V, that is, the same 5 circles with the same step.
In version 00.01.01 this is repeated 4 times - we can assume that this is for 4 channels. But I don’t understand why in version 00.01.02 this is repeated 12 times. Three times per channel?
