Is anyone willing to share their key.data file? Or has one been attached to post already? Looking at libscope-auklet.so inside sparrow apk, there are two references where it looks like it's reading licensing information near start of each function.
CApiLicense::ApiLicense_SetLicenseKey(CApiLicense *, __int64)
CApiLicense::getLicenseKey(__int64 a1, RString *a2, size_t *a3)
> sub_256818(&CApiLicense::LICENSE_PATH, "Key.data"); # I think this function just reads data from the device
In both license related functions, it looks like it reads the data from key.data near start of code then processes it. Would be helpful to see some actual data to understand what is going on.
Also, it is likely worthwhile to dig into the "opt" related functions as part of CAPiLicense class in that same .so file. This might help with analysis of how things are handled.
For example, I believe this is checking whether license is valid for bandwidth:
![Hacking the Rigol DHO800/900 Scope](https://www.eevblog.com/forum/index.php?action=dlattach;topic=393928.0;attach=1911156;image)
