I haven't had any luck generating keys for bandwidth upgrade but it's easy to push the DHO814 vendor.bin. I get about 135MHz measured bandwidth with that (2.6ns rise time).
you are still being haunted by anti-aliasing rebel movement do you?
btw i copied all files from rigol folder of ver1.0.0.19 (DHO804 from factory), ver1.1.0.2 (DHO804 legit gel upgrade) and ver1.14 (DHO924 illegit hack) using RigolTool.exe and do files size and binary (data) comparison:
comparing ver1.0.0.19 (DHO804 from factory), ver1.1.0.2 (DHO804 legit gel upgrade), every files are the same except:
\data\cal_afe_bandwidth.hex
\data\cal_vertical.hex
\FPGA\BOOT.bin
comparing the legit copies above (both) with ver1.14 (DHO924 illegit hack), the differences are:
\app\Launcher.apk
\app\Sparrow.apk
\app\Webcontrol.apk
\data\default\cal_vertical.hex
\data\cal_adc.hex
\data\cal_afe_zero.hex
\data\cal_ddr.hex
\data\cal_lsb.hex
\data\Key.data
\vendor.bin
\FPGA\BOOT.bin
files in DHO924 dont exist in DHO804:
\data\cal_ext.hex
\FPGA\SPU_H12S1.bit
i also did recalibration on each version to see what files are changed in rigol\data:
recalibrating ver1.0.0.19, the following file is changed:
recalibrating ver1.1.0.2 the following files are changed:
recalibrating ver1.14 the following files are changed:
\data\cal_adc.hex
so during calibration, one or more of that files will be changed.
fwiw...
