On to Mech trying to upgrade his scope from DHO804 to DHO924 in the whole night... after reading carefully this thread, then creating full backup of original FW (DHO804 ver 00.01.00)...
doing upgrade by using souldevelop's tool
https://www.eevblog.com/forum/testgear/hacking-the-rigol-dho800900-scope/msg5077957/#msg5077957 for ver 1.00 FW to DHO924 model, creating problem weird voltage vertical offset on all channels.
and then copying full image v1.14 from first post
https://www.eevblog.com/forum/testgear/hacking-the-rigol-dho800900-scope/msg5074423/#msg5074423 , doing calibration at first also introduce some weirdness esp when trying to enter development mode and enable ADC gain, AFE zero during calibration. switching dso off, turn on again and calibrate in normal mode, now it seems ok... few issues with 804 -> 924 upgrade...
1) even though BW increased to 230MHz, but extra ringing on pulses (overshot on both UTG962's and Leo Bodnar's pulse shown below)
2) observing 200uV/div reveals some suspiciously low noise floor when plotted in FFT. upon close observation of a signal between 500uV/div and 200uV/div, i concluded, there some kind of averaging (boxcar or running average) going on at 200uV/div, from less dense spectral content on display, shown below.. cant complaint much for an extra feature.. (better something than nothing, if you dont like it, dont use it)
3) the DSO original serial number is lost (already saved in backup image), so lets wait until someone know how to decrypt-edit-encrypt back the vendor.bin
good thing is...
1) 50Mpts memory (10Mpts/ch if all channel enabled)
2) 230MHz BW (except ringy)
3) Bode plot menu appears, quick play with it, possibly it can be hacked by injecting external (middleman) signal?
4) Nice D (LA)and G (AWG) stickers at bottom screen next to channels button (that Fungus really hates)
fwiw...
![](https://www.eevblog.com/forum/testgear/hacking-the-rigol-dho800900-scope/?action=dlattach;attach=1907349;image)
