Hello,
I'm an happy owner of the Rigol DHO1074 tha fit well side by side on my desktop with my Siglent SDS1204X+.
I thank you very much all people that has contribued to become it hackable.
I performed it as desribe without issue. Thank's again to all of them !
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
I played with the DHO1074 today, and I noticed a strange thing.
The full sampling rate is only acheveiable on CH4.
On all others channels, I can get only 1G/s (one channel active at same time).
As writed in manual, full sampling can only be obtainable wih only one input active but that not on a specific channel.
Another point is if I enable 2 channels other than the CH4, the sampling rate is limited o 500Ms/s instead of 1Gs/s !
All seem to work same as if an "hidden" channel would be active ...
(It count 3 instaed of two acive channel)
Does anyone here had seen he same behaviour on his scope ?
Regards.
Frex
(Note: firmware installed is 00.02.04, hardware 2)
