Author Topic: Hacking the HDO1k/HDO4k Rigol 12 bit scope  (Read 186826 times)
Tom620 and 23 Guests are viewing this topic.
Offline markone
Re: Hacking the HDO1k/HDO4k Rigol 12 bit scope
« Reply #225 on: November 11, 2022, 07:12:55 pm »
Tested a bit more, it looks like you can only have a side by side or top / bottom layout.  Event table is kind of mandatory as the way protocol decoding info is displayed in the waveform is kind of hard to read the values of the frames.  If I want to take advantage of the full sample memory, stop and zoom to decode, I cannot do it... as soon as I change the timebase, it says TOO MANY EVENTS or something like that and it does not decode. If I set it to a timebase where it still decodes, the update rate is like 1Hz... for a 115,200 baud rate UART decoding!!!  No wonder why it hangs with a 45MHz SPI signal... and it does not even decode correctly the frames.  I really cannot understand Rigol, they did not do the basic testing before releasing the scope, like someone sitting with the scope and testing it?????
I've been busy with work so had only like 1-2 hour total to play with the scope, but will try make more tests during the weekend.
EDIT (TOO MANY EVENTS): The message I get is "There are too many results".  You can stop and zoom and get the packets.  But it works only up to 20ms timebase.  If you want to set 50ms or higher, then it says Operation Disabled.  Still a lot of freeze/reboot issues.
EDIT 2: Created new HDO1000 BUGs topic. https://www.eevblog.com/forum/testgear/new-rigol-hdo1000-12-bit-dso-bugs/
I agree 100%, what you describe is simply unacceptable, i would dare to say that this product line is not ready to be sold, given the situation i fear that i'll be forced to buy something else, probably an MSO5074, i already use it at a customer's lab and I think it is at least decent.
I smell that this time Rigol has outsourced FW/SW development to a new external supplier who is not up to par, something I'm seeing more and more often.
Offline oliv3rTopic starter
    • Rigol related stuff!
« Reply #226 on: November 12, 2022, 09:52:14 am »
Hmm, buggy behaviour of the HDO1k doesn't bode well for the HDO4k...more expensive, more half-finished features, more bugs? Time will tell.
Since the software stack tends to be 'identical' (or asian style copy->paste modify; then modify each version individually with the same fixes) quite likely. Also don't expect all bugs to be fixed on all platforms because of this. But hey, maybe they've learned how to do proper software development for the HDO  :-DD
Thanks! Lets keep bug discussions in that thread. I'll update the main post with this!
« Last Edit: November 12, 2022, 09:53:51 am by oliv3r »
Offline idolclub
« Reply #227 on: November 13, 2022, 09:11:30 am »
Rigol HDO 1000 and HDO 4000 has been renamed to DHO 1000 and DHO 4000 on November 7, 2022.
HDO1000 --> DHO1000
HDO4000 --> DHO4000
The following users thanked this post: oliv3r
Offline tv84
  • Country: pt
« Reply #228 on: November 13, 2022, 09:28:01 am »
HDO1000 --> DHO1000
HDO4000 --> DHO4000
Another bug??   :-DD
Offline tautech
« Reply #229 on: November 13, 2022, 09:30:18 am »
HDO1000 --> DHO1000
HDO4000 --> DHO4000
Another bug??   :-DD
Nah, they left those with the previous model.
Reset, starts from zero again.
Out of office and unavailable for a few days.
The following users thanked this post: tv84
Offline tv84
  • Country: pt
« Reply #230 on: November 13, 2022, 11:19:07 am »
The other was the little-endian model. Now it's the big-endian one!  ;D
The following users thanked this post: egonotto, eplpwr
Offline Fungus
« Reply #231 on: November 13, 2022, 11:48:57 am »
HDO1000 --> DHO1000
Suddenly all the ones with "HDO" on the front are worth a lot of money on eBay...
Offline 2N3055
  • Country: hr
« Reply #232 on: November 13, 2022, 11:56:18 am »
I see that naming on Rigol Japan and China...
Funny thing is if you Google translate it it will also "translate" DHO4000->HDO4000 in translated text  ... :-DD
Maybe LeCroy wasn't happy... ? ^-^
But I think why this premature push happened.. I missed this news (not following Rigol in detail..)  :
https://www.rigol.eu/NEWS/news/53.html
Now they have stockholders to answer to. There was probably large pressure to show something, anything,  despite not being ready...
And maybe even with a blessing of the board: "... phone manufacturers do it all the time, so can we.."
Offline Fungus
« Reply #233 on: November 13, 2022, 12:02:04 pm »
The reason is obvious: "November"
Offline markone
« Reply #234 on: November 13, 2022, 02:03:03 pm »
This is something that i'm sadly used to, lot of work rushed out of the door (under high management pressure) to meet deadlines commitments, with the certainty that there will be consequences  ...
Nowadays this is the main tragedy for FW developers, marketing promise and sell the impossible, than R&D has to keep the pace ... and sometime you loose the customer.
Offline bob808
« Reply #235 on: November 14, 2022, 08:36:43 am »
Yeah once they take your money the don't have any real incentive to fix it, or fix it quickly. They're not getting anything out of it, anymore.
This was an issue with computer gaming. Games would release barely playable and you'd have to hope they'd release an update fixing the issues. This was solved by offering games as a service. Always connected to the internet, they keep selling you stuff in the game, and seems to make sense. Games get better in time, they make more money.
Wouldn't be surprised if oscilloscope manufacturers would at least think about this, if not try it. You get the hardware for relatively cheap but you need a monthly subscription. They could find a way to make it work, upside being good software support. Kind of dystopic tho.
edit:
If we take this HDO1k/4k example in reality Rigol is a hardware making company trying to sell their hardware with somewhat functioning software. Just that all their hardware on the 1k/4k series is basically the same, and they use some software tricks to better monetize them.
Ideally they'd sell us the hardware and have truly open software, or at least leave the enthusiasts in the userbase to also get an alternative open-source app going on their hardware. Android/RK3399 fits the bill for this. But then again they wouldn't be able to sell the (relatively) same hardware for such large price differences (take HDO1074 vs HDO4804).
« Last Edit: November 14, 2022, 08:52:08 am by bob808 »
Offline TK
« Reply #236 on: November 16, 2022, 02:19:52 pm »
Are you opening it?
Unfortunately no, in case I need to return it
Offline TK
« Reply #237 on: November 17, 2022, 04:00:11 am »
I received my HDO1074 from Valuetronics in the US
Perfect!
Please let us know if the "upgrade" method from this thread is working.
adb works and I got the file with the private key.  I used the go program to generate the license codes, but did not try applying them, as they are for HDO4K...
Offline bob808
« Reply #238 on: November 17, 2022, 09:30:49 am »
anything interesting in logcat? can you get the dtb file?
Offline tv84
  • Country: pt
« Reply #239 on: November 17, 2022, 12:17:24 pm »
That's irrelevant. As stated before, the FW doesn't check that designation.
Offline trinacria
« Reply #240 on: December 05, 2022, 01:56:10 am »
Does the riglol upgrade work yet? Or is it still a work in progress? Can someone report if it has worked for them?
Offline lgo51
« Reply #241 on: December 05, 2022, 02:28:10 am »
Ditto - inquiring minds need to know   :-//
Offline skander36
« Reply #242 on: December 05, 2022, 09:57:58 am »
Did you check? In case they are not working for HDO1K you should get an error message. I don't think you will brick something.
Or you just returned it?
« Last Edit: December 07, 2022, 12:45:09 pm by skander36 »
Offline black_cat
  • Country: cn
« Reply #243 on: December 06, 2022, 05:06:13 pm »
Mini Desktop
Gesture(手势导航)
The following users thanked this post: thm_w, bob808, skander36, eklein, trinacria, EL_ID_ioT, namor
Offline tv84
  • Country: pt
« Reply #244 on: December 06, 2022, 06:10:53 pm »
If you are looking for someone who used the keygen in this thread to license his HDO, you can see it here.
The following users thanked this post: maxwell3e10
Offline maxwell3e10
« Reply #245 on: December 06, 2022, 06:43:48 pm »
Q: Does one really need adb.exe? How is it different from using telnet and su?
Offline trinacria
« Reply #246 on: December 06, 2022, 07:39:25 pm »
Oops, I realize now that I forgot to specify "for the 1k". At least we now have pics for both.
« Last Edit: December 06, 2022, 08:07:00 pm by trinacria »
Offline bob808
Offline markone
« Reply #248 on: December 07, 2022, 06:25:29 pm »
Here is the lic gen ... just needs the key file from the device to work ....
The device id being field 0 is just a guess as the code ignores that field anyways ...
Worked like a charm and couldn't possibly be easier
Tools used:
  • Android SDK Platform Tools
  • Go compiler
Usage [Windows]:
[b]./adb.exe connect [scope-ip]:55555
./adb pull /rigol/data/Key.data
go run .\rgtool.go
insert generated codes via SCPI interface on scope-website[/b]
A couple of question about that :
1) this script works also with HDO1000 scopes ?
2) what does mean "insert generated codes via SCPI interface on scope-website" ?
Offline skander36
« Reply #249 on: December 07, 2022, 06:44:54 pm »
Rigol EU keep it's promise and delivered the HDO1072 scope today.
Attached is the file rigol.go modified for HDO1000. (just two options from the whole list - BW7T20 and RLU).
For reverting to factory license configuration: :SYSTem:OPTion:UNINSTall.
Many thanks to AlphaRne and all that helped with this!
The scope is pretty impressive with this new UI, low noise frontend, and  sturdy aspect, and not the last web interface which is as fast as those from RTB2k series.
Cons: noisy fan.
LE: @markone - is about the web interface (SCPI Panel Control)
« Last Edit: December 07, 2022, 06:49:15 pm by skander36 »
The following users thanked this post: TK, the Chris, EL_ID_ioT
