Hold on, you're talking about the DS3121, DS1317(I guess it's a typo), while the picture is from a DS1307
![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
I gave another try to the kernel...
Updated building steps
here.
After a lot of work, I got something:
» Configure, compile and flash the kernel.
» Patch the existing uboot, because the bootcmd only reads 3MB, while there new kernel is larger. The kernel partition is 10MB so there's plenty of room available.
» Boot using the original flash rootfs.
However, there're still lots of issues:
» Screen needs fixing. I have no idea what configuration Hantek is using, but seems to be a simple framebuffer, not using the graphics engine at all, drawing everything by software.
But it looks like the framebuffer is passed from u-boot, so no special config is needed?
» This kernel is 5.4.92, while original is 5.2.0. Hantek uses several custom kernel modules for scpi, keypad, fpga... which will refuse to load because the kernel version doesn't match.
Additionally, I found a more recent kernel,
5.4.140, sadly we're tied to 5.2.0 for the same reasons.
I might try using "modprobe -f" to force loading, will be great if it works instead exploding or something
![Cheesy :D](https://www.eevblog.com/forum/Smileys/default/cheesy.gif)
Luckly for us, the original kernel is still available
here, and there're great instructions
here, so I'll keep working on it.
(Remove [ url] tags, it's a forum error)
git clone [url]https://github.com/Lichee-Pi/linux[/url] -b nano-5.2-flash
cd linux
touch .scmversion # Required to prevent build from appending a "+" sign to the kernel LOCALVERSION, or it'll make "licheepi-nano+"
export ARCH=arm CROSS_COMPILE=arm-linux-gnueabi-
make licheepi_nano_defconfig
make menuconfig
make -j8
» Current status: System dies after "Booting kernel...""
That 5.2.0 kernel has no DMA support, pretty crappy support overall, things that 5.4.92 fixed.
If at least I manage to boot it, I might try porting the patches from 5.4.92...
It's a shame that nobody with linux knowledge joins the business!
![Sad :(](https://www.eevblog.com/forum/Smileys/default/sad.gif)
