Author Topic: Hacking the DSO2X1X  (Read 207896 times)
Offline OLderDan
Re: Hacking the DSO2X1X
« Reply #625 on: April 10, 2024, 01:59:37 pm »
Sorry, I should have said memory depth. Before I applied the latest patch I was following along with a YouTube video showing how the thickness of the trace can be seen to change going from 4k I to 8m, but I didn't see the same difference and put it down to filtering smoothing out the trace. Than Immediately after the latest patch the trace became noticeably thicker unless I used HR mode or a lower memory depth.
This made me wonder, as the reason they sent me the patch was I complained of laggy inputs and random lockups, if there was a change to the filtering to lighten the process load, with the added benefit of a more accurate display trace.
« Last Edit: April 10, 2024, 02:07:09 pm by OLderDan »
Online Aldo22
« Reply #626 on: April 10, 2024, 02:47:40 pm »
@OLderDan: I'm not sure. Maybe DavidAlfa understands your question (is it even a question? I'm not a native speaker).
As a general tip for the DSO2000, I would say: Don't look for a fly in the ointment, just enjoy what a great tool you got for $150 and explore everything you can do with it.
People often pay too much for this tool and are then rightly disappointed.
Offline OLderDan
« Reply #627 on: April 10, 2024, 02:57:36 pm »
I agree with you entirely and I am happy to embrace all this bargain oscilloscope has to offer, including it's limitations. Through playing around, I have found great settings for trigger that have stabilized displays of unsynchronised waveforms, and through specifying the hex bit, triggering in useful parts of my uart streams etc.
Learning how to interpret the trace has taught me the real world differences of the acquisition settings and opened my circuit exploration far beyond what I was able to achieve before I bought this scope.
Offline jovan_kineas
  • Country: jp
« Reply #628 on: April 14, 2024, 04:30:27 pm »
Hello, does anyone know how I can make the UART and I2C decoder show the letters instead of doing it by code? For example, I would like it to show an "A" instead of a "41" or at least show them together, my firmware is 3202 and Software 1.0.2.0.0 (221028.00), thanks
« Last Edit: April 14, 2024, 04:32:12 pm by jovan_kineas »
Online Aldo22
« Reply #629 on: April 14, 2024, 04:57:42 pm »
Hello, does anyone know how I can make the UART and I2C decoder show the letters instead of doing it by code? For example, I would like it to show an "A" instead of a "41" or at least show them together, my firmware is 3202 and Software 1.0.2.0.0 (221028.00), thanks (Attachment Link)
Install Patcher: https://drive.google.com/drive/folders/18kLCiv3E7FusO-ioO8oENj5oUiyYId_8
Info: http://bit.ly/3I8CfAJ
The following users thanked this post: jovan_kineas
  • Country: jp
« Reply #630 on: April 14, 2024, 06:23:52 pm »
Hi, Thank You, it works for me  :-+
  • Country: jp
« Reply #631 on: April 14, 2024, 08:56:28 pm »
Please correct me if I'm wrong but the UART mod called "Patcher" makes i2C decoding stop working? That function no longer decodes me. The message "Please adjust the Triger" or "please adjust the base time" always appears, before it gave me the impression that it was half working.
Offline Freelander
« Reply #632 on: May 02, 2024, 09:01:13 am »
Hello all you good folk.  ;D
Ok, I am slightly confused - so my doctor says ;-) ....
Question is basically this ?.
I have on order a jelly bean DSO2D10. I want - of course, to convert to the 2D15. I note the thread has taken many side channels, but could someone please advise the method to use for the change ?
Is it simply the firmware (currently) - dso3kb_20230327.upk -  on a usb stick with the original first post - do_other_update - file and nothing else ?
My very best regards to all you great modders and hackers.
Joe
Offline DavidAlfa
« Reply #633 on: May 02, 2024, 09:02:20 am »
Read the FAQ!
The following users thanked this post: Freelander
Offline Freelander
« Reply #634 on: May 02, 2024, 09:05:50 am »
David, thank you for the reply and apologies if I am not up to date here. Normally, the first post is edited to keep up with the methods. I do not see a FAQ. I may well be being thick and if so I am sorry.
Regards, Joe. and thanks for the great work,
Offline Freelander
« Reply #635 on: May 02, 2024, 09:08:34 am »
AH ! just saw FAQ in your suffix - doh - apologies.
Offline DavidAlfa
« Reply #636 on: May 02, 2024, 09:56:30 am »
Should be there, but as I'm not the OP I can't!
Offline Freelander
« Reply #637 on: May 02, 2024, 10:09:09 am »
thanks David.
Offline warham
« Reply #638 on: May 08, 2024, 08:35:11 am »
The following users thanked this post: morgan_flint
Offline DavidAlfa
« Reply #639 on: May 08, 2024, 02:35:34 pm »
This thread is only for hacking, please keep it on topic.
For usage, doubts, updates, bugs... use the main thread: New Hantek DSO2X1X models.
Spreading the information between different threads will only cause confusion, this update has already been mentioned.
Thanks!
« Last Edit: May 08, 2024, 02:38:51 pm by DavidAlfa »
The following users thanked this post: dirtmover
Offline Sami
« Reply #640 on: June 23, 2024, 05:13:35 pm »
Hi everybody. Please bear with me. I am a returning Electronics Technician.
Have been disconnected from electronics for more than 40 years, worked as a Technical Writer, and now as I am retired, nostalgia pulled me back to electronics again.
I just purchased a Hantek DSO2C10, thinking it includes a signal generator, but disappointed.
I tried your hack with the latest firmware, but it didn't work.
I thought maybe they modified the newer firmwares so that they don't check for additional files in the root.
Any suggestions?
I thought maybe if I get an older firmware, then it could work. Tried a couple I got from somebody on the internet (years 2022 & 2021) but still failed.
Your help/advice would be greatly appreciated.
Online Aldo22
« Reply #641 on: June 23, 2024, 06:36:03 pm »
What does [Utility] -> "System Info" say?
"Model" should read: DSO2D15 after applying the patch "2D15 conversion"
Is the signal generator hardware there?
Offline Sami
« Reply #642 on: June 23, 2024, 10:06:01 pm »
No, unfortunately, it still reads DSO2c10.
Also, you can see at the bottom the indications of channels 1 and 2, and no indication of wave generator.
By the way, the firmware version as received was 3209 and stays the same after successful update, which means - to me - the system keeps the version as long as no newer version is introduced.
Thank you for your care.
« Last Edit: June 23, 2024, 11:31:14 pm by Sami »
Online Aldo22
« Reply #643 on: June 23, 2024, 10:27:23 pm »
So you applied this patch and the model number has not changed?
https://drive.google.com/drive/folders/1AbaHXFGgBeKaUuzLmC5P5jtotScjxTgf
I've never heard that before.
Offline Sami
« Reply #644 on: June 23, 2024, 11:42:16 pm »
NO KIDDING!!!  :clap: :clap: :clap:
Thank you so much.
Your "Conversion" file worked like magic.  :D
Next step, I'll test it :)
AND, yes, it works like butter :)
Thanks again!! You made my week :D
Where are you in Switzerland, if I may ask? I'm in Basel.
« Last Edit: June 24, 2024, 06:17:28 am by Sami »
Online Aldo22
« Reply #645 on: June 24, 2024, 08:46:16 am »
It's not mine, it's from DavidAlfa.
The entire FAQ is here: https://www.eevblog.com/forum/testgear/hantek-dso2x1x-models-master-thread/
I had already pointed out the patch to you above: after applying the patch "2D15 conversion"
You must have missed that.
Central Switzerland
Offline johnka
  • Country: gr
« Reply #646 on: July 29, 2024, 10:00:08 am »
I'm thinking to buy the 2C10 which is much cheaper than 2D15.
Is there any way to know if it has the required components soldered before buying it?
I live in Greece and it's impossible to find these components locally.
Offline DavidAlfa
« Reply #647 on: July 29, 2024, 03:19:18 pm »
No, but it's very likely to include them.
Couldn't you get them from AliExpress anyways?
Offline johnka
  • Country: gr
« Reply #648 on: August 14, 2024, 06:04:30 pm »
I used a discount coupon on aliexpress and I got the 2D10 (almost same price with 2C10 - €153) to make sure it will have the required components for the generator.
Should I follow the same instructions to convert to 2D15 like it was a xxCxx model?
Should I update to the latest version? It came with SW 1.0.3.0.0 230327.00 and FW 3205.
I have a question about the probe. On x10 attenuation it mentions max input voltage<600V DC+Peak AC. Does it mean 1200 Vpp or 600 Vpp? 230V(rms) is 650Vpp. Can I probe that?
Offline BlownUpCapacitor
  • I kinda suck at the art of electronics tbh
« Reply #649 on: August 14, 2024, 06:11:10 pm »
Read DavidAlfa's FAQ found in this signature
Hehe, spooked my friends with an exploding electrolytic capacitor the other day 😁.
