Dude
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
. Don't take it too bad, but adding the chip ID is simply useless. The read/write algorithm is pretty different for spi nand.
Not a bug problem. For the SPI nor, you simply throw the read command and the address, and get the data.
For nand, you must fetch the nand page to the output buffer, wait for it to complete, then read the buffer.
Same for writing, for NOR you erase the block and write the data.
For NAND you have to erase the block, send data to the buffer, and send the programming command. And again wait.
That's what I've been doing. Almost working but there are strange bugs with the internal handler, sometimes it doesn't like sending comands.
I guess if it's a timing issue. I don't know but it's driving be mad!
Also, the spi nand as an OTP area. 10pages x 2048Bytes. I didn't check it the contents, but who knows.
As its name says, it's only one-time programmable. Who knows if hantek wrote some unique data there, like calibrations and such.
Other thing I've been trying is to buiild u-boot with usb support. But no way. The documentation is null, so guess what the *** is going on.
Why the hell they added options for sunxi/suniv, if when you enable them you get all kinf of "not defined" or "not implemented" errors
Edit: And now it seems the spi flash os gone. No matter what flash, the dso is dead. Will put the original memory back and bye!
I'm out of here. Burn all that chinese crap down!
