You'll get better performance if using Hscope Android software with this scope. See the page below for Hscope verified specs when using that software. The experimental mode turns on 10-12bit capability in scopes with this chipset. "Automotive mode" gives you longer recording functions.
Martin Loren, the creator of Hscope, is regularly improving Hscope adding more and more capabilities. He is on Telegram everyday, and interfaces regularly with his ever increasing user base. Hscope covers a variety of USB scopes, from Hantek, Loto, and many others.
If you don't need a whole lot of bandwidth, look at his own scopes, the HS502 and HS512, 12 bits, and very low noise. They are sold on his website.
https://www.martinloren.com/instrustar-isds205/
