Author Topic: Hacking the $18 Fnirsi DSO152 portable oscilloscope  (Read 1571 times)
Offline david.givenTopic starter
« on: April 17, 2024, 09:15:39 am »
Warning: I made this.
As a 200kHz oscilloscope I don't think it's worth much, but as a CH32F103-based Blue pill development board in a nice case with a high-bandwidth screen, battery and charger and USB-C, it's potentially pretty useful.
I've since found out that Fnirsi make the DSO153, which is an upgraded model with signal generation support. This looks similar but has a different microcontroller and a more complex board and, obviously, an output analogue stage. I can't get a good picture of what the microcontroller is but it's likely to be an upgraded CH32F. It's another $10 more expensive, which takes it out of the sub-$20 sweet spot of being-cheap-enough-to-buy-as-a-component that the DSO152 is in, but if anyone does want to build a custom diagnostic tool it might still be worth a look...
The following users thanked this post: tunk, Kim Christensen
Offline Atlan
  • Country: sk
Re: Hacking the $18 Fnirsi DSO152 portable oscilloscope
« Reply #1 on: April 17, 2024, 07:09:30 pm »
One pin is enough for programming ? I program the CH32v003 via the SWDIO pin.
FNIRSI 1013D Always provide a picture or video with the problem where the parameters of the oscilloscope are visible, and a picture of the diagnostic screen with the values.
« Reply #2 on: April 18, 2024, 09:07:24 am »
The V models are RISC-V based, though, and AFAICT they use a different debugging protocol; I've never used one. This one's an ARM and uses the standard two-wire SWD protocol (which is both a good thing, because it's standard, and a bad thing, because it uses two wires...).
The following users thanked this post: Atlan
Offline Just_another_Dave
« Reply #3 on: July 27, 2024, 12:47:46 pm »
DSO153 is supposedly able to measure up to 1MHz, which could be enough for some testing on the go or for conducting small repairs (e.g checking if a power converter is working fine). However, it seems to be unable to save measurements, so modifying its firmware to be able to send them to a computer over usb could make it more useful
Online coromonadalix
« Reply #4 on: July 27, 2024, 02:11:10 pm »
 :-+ :-+ :-+  loll to play pong on it   :palm:
kudos
