Author Topic: Hack of Sigllent spectrum analyzer ssa3021X?  (Read 445261 times)
Offline trp806mo
Re: Hack of Sigllent spectrum analyzer ssa3021X?
« Reply #1075 on: January 01, 2023, 06:25:47 pm »
Is it possible to enhance the RBW to 3Mhz on a SSA3021X+ in order to speed up the SWT with the python script for example (I prefer not to try it if it's not possible in order not to break my warranty) ?
Offline ahaladjian
  • Country: cy
« Reply #1076 on: January 02, 2023, 07:05:42 pm »
Hello
I have Sigllent Spectrum analyzer with model number SSA3021X.
SW1 is 1.3.9.6 can i upgrade V3.2.2.4.0?
can this model upgrade from 2.4Ghz into 3.2Ghz?
regards
Antony
Offline tautech
« Reply #1077 on: January 02, 2023, 07:30:15 pm »
Hello
NO !
V3.2.2.4.0 is firmware for 3000X Plus models.
The correct firmware is here:
https://int.siglent.com/download/firmwares/?ProId=29
Oh please, yours is a 2.1 GHz model, not 2.4.
It will upgrade and the methods are in this thread, please study it.
Offline ahaladjian
  • Country: cy
« Reply #1078 on: January 03, 2023, 06:59:46 am »
where can i find the firmware 7.07?
Offline ahaladjian
  • Country: cy
« Reply #1079 on: January 03, 2023, 07:28:44 am »
hello
thxs for replying, my current SW1 is 1.3.9.6 and HW is 0C.03.00
do i have to upgrade to the latest firmware? SSA3000X Firmware – V1.3.9.8 (Release Date 08.15.21 )
or SSA3000X_Firmware_V2.1.1.3R1 (Release Date 09.16.22 )
I was reading the methods of how to upgrading and i have some questions to ask you, before i proceed the procedure of hacking my siglent specrum analyzer, do i have to upgrade to the latest version? from SW1 1.3.9.6 into 1.3.9.8 or 2.1.1.3R1?
i heard about firmware version 7.07 where can i get that file ?
regards
Antony
Offline uski
« Reply #1080 on: January 05, 2023, 07:50:27 am »
I found it is NOT for the faint of the heart.
Initial state: brand new SSA3021X Plus with firmare 3.2.2.5.0
No so. Currently all of this can be done by people with pacemakers or even TAH's  :D but many continue to not read the latest developments... this thread is only 43 pages long and most of them only repeat what has already been said obscuring important details.
The easiest path is here.
Ah yes I saw that post. However, I like to understand what I do... I was not going to hex edit a bunch of bytes in a firmware image not knowing what it does. The more complicated way is much more transparent.
I think it would be good if you could explain what this modification does. I am assuming you are changing the header of the upgrade file and its checksum, so that the SSA applies the SVA firmware, thinking it is an SSA firmware. But more details would really help!
As you say, a lot of minimalistic, 2-3 lines post, require a lot of context and are really hard to process for people new to this thread. 40+ pages is a lot of information and we should not require people to read everything to do the hack.
By posting what I did, from A to Z instead of requiring people to compile a bunch of partial information, I was hoping to give a one-stop-shop post with clear and transparent explanations. But yeah, it's likely the way you shown is much easier and simpler :-+ could just do with more explanations
Thanks for your help, definitely would not have been possible without you and others :)
Offline tv84
  • Country: pt
« Reply #1081 on: January 05, 2023, 10:26:21 am »
That's exactly that and only that!  :-+  (it's in the thread somewhere...)
You did well, no worry.
Offline el_man
  • Country: bg
« Reply #1082 on: January 05, 2023, 02:46:26 pm »
Hello and Happy New Year! to everyone
I've just received my new SSA 3021X plus and I'm very happy but the firmware is 3.2.2.5.1R20
And Unfortunately the backup SSA3000X+_backup_11411.ADS doesn't work for me :(
The usb stick is empty only with ads file. Maybe I'm doing something wrong or it is related to the firmware
I also try downgrade to 3.2.2.5.1R1 the screen show progress but  after rebooting the firmware is the same.
Any ideas?
P.S. I'm not familiar with linux but is it anywhere instructions how to make backup trough telnet and of what?
I've already hex modified 3.2.2.5.1R1 ads file.
« Last Edit: January 05, 2023, 05:30:10 pm by el_man »
Offline DeDe
« Reply #1083 on: January 05, 2023, 07:00:03 pm »
Regarding not working backup SSA3000X+_backup_11411.ADS - of course script will only work under following conditions;:
  • Before crossflash on original SS3000X *Plus* devices with V3.2.x.y.z firmware
  • Plugged in USB-Stick formatted with a single FAT32 partition
  • USB-Stick should allow write access: try with File|Create Folder if you can create a new folder on your stick
Otherwise reformat the USB stick with FAT32 (not ExtendedFAT) and with MBR (master boot record).
If it still does not work after that, it will be necessary to go the way over telnet and to re-mount the mass-storage filesystem once in RW-mode.
Offline el_man
  • Country: bg
« Reply #1084 on: January 05, 2023, 07:37:37 pm »
Thank yo so much!
I've already tried all of this, usb stick is freshly formatted.
The device is in initial state with its firmware 3.2.2.5.1R20
How about telnet access I've succeed trough pot 10101, but and how to change the filesystem to RW-mode?
Offline DeDe
« Reply #1085 on: January 05, 2023, 08:18:34 pm »
I just tested it again, I think using File|Create Folder works because the main application process /usr/bin/siglent/Aladdin runs as root and therefore it can write.
So telnet to your device and execute:
mount -o remount,rw /usr/bin/siglent/usr/mass_storage/U-disk0
Then load this "pseudo" firmware update with backup script.
After you are done just restart the device once, then all filesystems are read only again.
Offline el_man
  • Country: bg
« Reply #1086 on: January 05, 2023, 10:01:54 pm »
Thank you again so much For the help DeDe!
I succeeded in everything and the upgrade is finished successfully
But unfortunately It seem like something is missing in VNA part maybe This VNA cable.
The Smith chart was total Mess and after adding the two configuration files na_1p na_2p it becomes more or less normal at least now is in the contour of the chart :D
But the port Doesn't react to any Load 50ohm Close - Nothing!
Where is this "VNA cable" and is there a fix to this?
Any other guy with same version of this firmware 3.2.2.5.1R20 Does Experience the same problem?
My unit is quite New - manufacture date is 13.12.2022 Maybe because of the unlucky date they stop putting the cables ;)
or at lest at This date :'(
Any help will be Highly appreciated!
« Last Edit: January 05, 2023, 10:05:03 pm by el_man »
Offline RoV
« Reply #1087 on: January 05, 2023, 10:15:52 pm »
Sure you connected to the right port? Port for S11 measurements is TG, not RF in.
Measurements will be very inaccurate without a calibration.
Offline DeDe
« Last Edit: January 06, 2023, 11:46:11 am by DeDe »
Offline ThomasM...
« Reply #1089 on: January 08, 2023, 04:17:22 pm »
Hello and a happy new year to all
I have a problem with my "open" SSA3032x (w/o SN)  FW version 1.3.9.7
Refelection mode measurement is only able on Trace C and cannot changed to other trace No
Not sure whether this problem is caused by "open procedure at all", FW Bug or defect of my device.
Hopefully someone can help
Thanks and regards
Thomas
Offline tautech
« Reply #1090 on: January 08, 2023, 05:35:29 pm »
Thanks and regards
Thomas
First sanity check is to Preset to Factory settings. How Preset operates is selected within the System menu.
Offline ThomasM...
« Reply #1091 on: January 08, 2023, 06:25:11 pm »
Thanks and regards
Thomas
...no change, problem is still present
Offline Bicurico
  • Country: pt
    • VMA's Satellite Blog
« Reply #1092 on: January 08, 2023, 09:32:24 pm »
That seems to be normal behaviour.
On my SSA3021X trace C is used and cannot be modified.
Not sure why this is, but I guess that this way the device does not touch the more commonly used traces A and B.
Offline ahaladjian
  • Country: cy
« Reply #1093 on: January 09, 2023, 01:57:52 pm »
hello
is anyone here who can help me please!!!
many thanks
Antony
hello
regards
Antony
Offline ThomasM...
« Reply #1094 on: January 10, 2023, 05:59:59 pm »
ok thanks
Also i found a video in the web describing reflection measuring mode.
Was also on trace c
Offline ThomasM...
« Reply #1095 on: January 10, 2023, 06:04:53 pm »
hello
many thanks
Antony
hello
regards
Antony
...update to 1.3.9.7 and than make your modifications.  Further FW update not necessary because 1.3.9.8 is only for newer HW
Offline Zbych_
« Reply #1096 on: January 18, 2023, 09:21:51 am »
No, you can use 1.3.9.8 with old hardware.
Offline ThomasM...
« Reply #1097 on: January 18, 2023, 07:35:53 pm »
...however it is not necesarry to update to 1.3.9.8 because the diffeence to 1.3.9.7 is only the compatibility to new HW parts within the Analyzer
I am wrong? Than please explain more in detail
Offline Crambone
« Reply #1098 on: January 22, 2023, 02:55:31 am »
Anyone looking to sell one already hacked?
Offline HighPrecision
« Reply #1099 on: January 23, 2023, 12:33:56 pm »
my new SSA3021X+ (fw: 3.2.2.51R1) is just hacked with TV84 patched SVA firmware (backup done first), same version of SSA, all went OK and the VNA module appeared in system info list as permanently activated as TG, all other are time-limited demos.
The model declared remain as SSA3021X+, I've used the script to change to 3.2GHz (3032)... activation keys are accepted only with SVA1000X model specified in the script, after a factory reset the model is automatically changed in SSA3032X+ in system info, s/n UNchanged as the original (SSAxxx...)
Then I used the 'ALL' key to enable all options, 'DFT' option appeared in the list with all other permanently activated.
My question:
IT's necessary to change the info model to SVA1032X modifying the 'NSP_trends_config_info.xml' file ?
Thanks
