Author Topic: Hack of Sigllent spectrum analyzer ssa3021X?  (Read 455918 times)
Offline ShaneEEV
Re: Hack of Sigllent spectrum analyzer ssa3021X?
« Reply #650 on: May 01, 2019, 04:24:03 am »
TV84,
How does one "remove the hack"? ( I can see logging-in and copying the backed-up files back to the operating files. Perhaps you meant that?
I performed the upgrade on my new SSA3021X, but I see my SN has been 'X'd out.
Any way to get the feature set and retain the proper serial number?
Thanks, in advance!
Shane
Offline tv84
  • Country: pt
« Reply #651 on: May 01, 2019, 11:08:06 am »
You can reinsert the S/N via SCPI.
Try something like
:SRLN <serial_num>
(I don't remember if this is the right command for the SSA but should be here in the forum...)
« Last Edit: May 01, 2019, 11:10:29 am by tv84 »
Offline ShaneEEV
« Reply #652 on: May 02, 2019, 04:03:38 am »
Thank you, TV84. I don't seem to.be able to get an http session with the SA at this time.
I found a manual on the SCPI commands for the SA, but I don't see any command that allows configuring the S/N for the SA.
Best Regards,
Shane
« Reply #653 on: May 02, 2019, 05:39:43 am »
Best Regards,
Shane
Of course, it's a hidden undocumented command.
From P7 of the programming manual:
https://www.siglentamerica.com/wp-content/uploads/dlm_uploads/2017/10/SSA3000X_ProgrammingGuide_PG0703X_E04A.pdf
Telnet mode. The telnet SCPI service is available on port 5024.
Offline TTH
« Reply #654 on: May 05, 2019, 12:32:40 pm »
TV84 is correct:
:SRLN <serial_num>
... is the correct SCPI command to set the serial number (note the space after :SRLN)
Thanks to TV84 :)
Offline ShaneEEV
« Reply #655 on: May 06, 2019, 12:57:29 am »
Thank you TauTech and TTH!
I have successfully logged-in as you suggested, but I'm having difficulty getting the SN set.
I have tried:
:SLRN SSA3XABC1t2682
:SYST:SLRN SSA3XABC1t2682
:SYSTCONF:SYST:SLRN SSA3XABC1t2682 (Number changed to protect the innocent)
Nothing seems to set the serial number... Should I enter some sort of save command to fix the change into the SSA???
I skimmed through the manual- perhaps I missed the details???
Your hints are very helpful!
Thank you, again!
Shane
« Reply #656 on: May 06, 2019, 01:18:00 am »
Sanity check *IDN?
Does this return the correct answer ?
For SCPI it's always a good idea to prove you have a valid connection first.....especially if you're a programming novice like me.  :-[
The following users thanked this post: ShaneEEV
Offline ShaneEEV
« Reply #657 on: May 06, 2019, 02:38:50 am »
Hi TauTech,
Yes, *IDN? returns the scope model and SNXXXXXXXXXX, 1.2.9.2.a
« Reply #658 on: May 06, 2019, 02:58:32 am »
Hi TauTech,
See the little 't' in your SN# ? That doesn't look right to me. Double triple check it belongs there.
Offline ShaneEEV
« Reply #659 on: May 06, 2019, 03:43:52 am »
That's not the real SN of my SSA. When I do the *IDN? I get all X's for the SN.
« Reply #660 on: May 06, 2019, 04:00:06 am »
Yes I know but it should be SSA3X***#R####
Yes, when they are hacked XXX...... is the SN#.
Someone here will pop by and rescue you.  :)
They go just fine without a SN# so no need to worry unduly.
Offline ShaneEEV
« Reply #661 on: May 06, 2019, 04:05:38 am »
Tautech-
Thank you- my SSA has the SN of this form:
SSA3X***2R####
I hope to be rescued! Ha ha! It would be good to put the SN right, even though it doesn't affect the function of the analyzer.
I appreciate your kind replies!
Best Regards,
Shane
Offline Emo
« Reply #662 on: May 06, 2019, 06:26:22 am »
I have tried:
Thank you, again!
Shane
Just for the record and for others that might want to use this method.
In your SCPI commands you seem to have made a typo; :SLRN, should be :SRLN
Offline rf-loop
« Reply #663 on: May 06, 2019, 06:58:47 am »
I have tried:
Thank you, again!
Shane
Also, regardless of whether it worked or not. Until today, I have not seen Siglent serial numbers what include other than capital letters and numbers.
EV of course. Cars with smoke exhaust pipes - go to museum. In Finland quite all electric power is made using nuclear, wind, solar and water.
Offline tv84
  • Country: pt
« Reply #664 on: May 06, 2019, 08:54:53 am »
It's been a long time but I think when you force the S/N to be the one you want with the SCPI command, you automatically disable the hack that most people use.
After activated, if I remember correctly, the hack works by checking if the S/N is XXXXXXXXX.
But I could be wrong...
Offline TTH
« Reply #665 on: May 07, 2019, 02:38:46 pm »
TV84 is correct:
The SCPI command
:SRLN SSA3X*********
... changes the serial number
... but results in the creation of a new NSP_sn_bandwidth.xml file (and backup)
... populated with  the serial number - but no option licence keys : (
It does appear that you have to live with the XXX serial number if you want all the options.
Offline tv84
  • Country: pt
« Reply #666 on: May 07, 2019, 05:49:22 pm »
TV84 is correct:
The SCPI command
It looks like Alzheimer hasn't catch me yet...  I had this idea from what I saw in my code analysis although I didn't asked nobody to test. Now it's confirmed!
Offline Pinkus
« Reply #667 on: May 08, 2019, 07:54:36 am »
However, there is one drawback: AFAIR, Siglents software EasySpectrum will not work without the serial number. If you would like to use the analyzer for doing pre-compliance measurements, the software saves a lot of time and makes things much easier.
However: I cannot test/confirm this, as my unit does have serial number and all options. Maybe somebody can double check this.
But I am pretty sure that EasySpectrum was very sensitive about the connected analyzer.
Offline TTH
« Reply #668 on: May 29, 2019, 08:08:51 pm »
Easy Spectrum functionality works (both Monitor and EMI) with Serial XXXXXXXXXX
Offline electronic_eel
« Reply #669 on: May 29, 2019, 10:26:13 pm »
There is a new firmware 1.2.9.3a out.
This one seems to block telnet access to the device. It is not available on the regular port 23, and also not on 10101 (which some other Siglent products use).
Downgrading to 1.2.9.2a is possible, but does not bring telnet access back!
So I wouldn't recommend to install this update for now.
Offline BillB
« Reply #670 on: May 29, 2019, 11:10:11 pm »
Seems like Siglent is starting to secure their product line.  :(
Offline tv84
  • Country: pt
« Reply #671 on: May 31, 2019, 05:37:04 pm »
The new FW SSA3000X_v1.2.9.3a has 2 interesting files, besides new versions of the common ones.
See attached.
And, of course, SHELLCMD was removed from the main app.  ;)
« Last Edit: May 31, 2019, 05:54:30 pm by tv84 »
Online markus_jlrb
« Reply #672 on: May 31, 2019, 06:07:57 pm »
@tv,
how to mod the lines from
rm -f to echo rm -f
or  from
rm -f to # rm -f
Any ide?
Markus
« Reply #673 on: May 31, 2019, 06:50:24 pm »
You'd have to package a modified ADS update file. The format is obfuscated and sometimes also encrypted. You can find some info here: https://www.eevblog.com/forum/testgear/siglent-ads-firmware-file-format/. But while the descriptions there are probably enough to get someone determined on the right track, they are not simple recipes you can just follow along. tv84 seems to have mastered this though.
Just an idea: if someone creates a modified ads file, wouldn't it be better to create one that just re-enables the telnet service and doesn't do anything else, like replacing ecomb? This way you could just install the regular update and install the re-enabler.ads afterwards. When Siglent releases the next update, it will most probably disable telnet again, so you could use the same re-enabler again and wouldn't have to do modifications again.
Offline tv84
  • Country: pt
« Reply #674 on: May 31, 2019, 06:56:04 pm »
rm -f to echo rm -f
Test at your own risk.
This is the official ADS with additional.sh "slightly" modded.
If you already installed the official update, you already had telnetd deleted, so in that case this won't work.
« Last Edit: May 31, 2019, 07:14:23 pm by tv84 »
