Hi guys, new owner of the Siglent SSA3021X here. It was delivered just yesterday.
I checked the firmware version, and I have 8.1! So I thought I would try this mod see how things goes. Thanks to the V0.5 tutorial (from
post #289) things went pretty smoothly, and I have all features unlocked and 3.2GHz bandwidth as of now.
I just wanted to point something out though. When I was renaming the files, the filesystem apparently was remounted automatically, and went back to read only mode. It seems like the original files were rewritten as well, so I had to remove the _x previously moved files, and rename the newly created files again, after remounting the filesystem in rw mode. See below.
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org am335x-evm
Arago 2013.05 am335x-evm
am335x-evm login: root
Password:
root@am335x-evm:~# cd /usr/bin/siglent/firmdata0
root@am335x-evm:/usr/bin/siglent/firmdata0# ls -l
-rwxr-xr-x 1 root root 471 Jul 8 --:-- NSP_sn_bandwidth.xml
-rwxr-xr-x 1 root root 606 --- -- --:-- NSP_trends_config_info.xml
drwxrwxr-x 2 1000 1000 4240 Jan 1 2000 calib
-rwxr-xr-x 1 root root 544 Jul 8 --:-- nsp_data_b
root@am335x-evm:/usr/bin/siglent/firmdata0# cd /usr/bin/siglent/usr/backup
root@am335x-evm:/usr/bin/siglent/usr/backup# ls -l
drwxr-xr-x 2 root root 4240 --- -- --:-- calib
root@am335x-evm:/usr/bin/siglent/usr/backup# cd /
root@am335x-evm:/# cp -R /usr/bin/siglent/usr/backup /usr/bin/siglent/usr/mass_storage/U-disk0/SA-backup
root@am335x-evm:/# cp -R /usr/bin/siglent/firmdata0 /usr/bin/siglent/usr/mass_storage/U-disk0/SA-firmdata0
root@am335x-evm:/# mount -o remount,rw /dev/ubi2_0 /usr/bin/siglent/firmdata0
root@am335x-evm:/# cd /usr/bin/siglent/firmdata0
root@am335x-evm:/usr/bin/siglent/firmdata0# mv NSP_sn_bandwidth.xml NSP_sn_bandwidthx.xml
root@am335x-evm:/usr/bin/siglent/firmdata0# mv NSP_trends_config_info.xml NSP_trends_config_infox.xml
root@am335x-evm:/usr/bin/siglent/firmdata0# mv nsp_data_b nsp_data_bx
mv: can't rename 'nsp_data_b': Read-only file system
-rw-r--r-- 1 root root 471 Jul 8 --:-- NSP_sn_bandwidth.xml
-rw-r--r-- 1 root root 471 Jul 8 --:-- NSP_sn_bandwidthx.xml
-rwxr-xr-x 1 root root 606 --- -- --:-- NSP_trends_config_infox.xml
root@am335x-evm:/usr/bin/siglent/firmdata0# rm NSP_sn_bandwidthx.xml
root@am335x-evm:/# sync
root@am335x-evm:/# logout
This is exactly what I have in both folders after the mod.
root@am335x-evm:/# ls -l /usr/bin/siglent/firmdata0
-rw-r--r-- 1 root root 471 Jul 8 15:52 NSP_sn_bandwidthx.xml
-rw-r--r-- 1 root root 150 Jul 8 15:55 NSP_trends_config_info.xml
-rwxr-xr-x 1 root root 544 Jul 8 15:52 nsp_data_bx
root@am335x-evm:/# ls -l /usr/bin/siglent/usr/backup
-rwxr-xr-x 1 root root 471 Jul 8 15:42 NSP_sn_bandwidthx.xml
(The dates are masked for most files since I lost my logs, and I have no record of the original dates during the operation, I chose to mask them. I rewrote these commands to give you guys an idea of what happened.)
Anyway, my spectrum analyser is unlocked, I have XXXXXXXXXX serial number and "Permanent" validity on all options, so I assume everything is fine.
Now, I'm still on 1.2.8.1 firmware, and as far as I understand, I need to:
1. Revert the mod (CHAPTER 5)
2. Run the upgrade 1.2.8.1 -> 1.2.8.3
3. Do the mod again (CHAPTER 3)
Am I right?
As far as I heard, the latest firmware is still compatible with the mod, so it is safe to upgrade?
Thank you guys!
