Author Topic: Hack of Sigllent spectrum analyzer ssa3021X?  (Read 443957 times)
Re: Hack of Sigllent spectrum analyzer ssa3021X?
« Reply #250 on: January 09, 2017, 09:14:18 pm »
Hey all!
Let me just quickly recap my story about bricked SSA. I have sent it back for repair (under warranty) and received it upgraded to the latest version and fully unlocked! ;D It looks like they only flashed the faulty partition and left the user data intact. I am not sure if they didn't notice the modifications or they just let me go with it.  I would recommend anyone with bricked device that is still under warranty to try and send it back. It could be the easiest solution.
Successful hacking in 2017!
We ask who is "they" ?  :-//
Offline ebclr
« Reply #251 on: January 09, 2017, 10:58:36 pm »
Flash dump 100.0..02.07.07
http://www.luximetro.com/SSA3021X.rar
The following users thanked this post: Pinkus, KeBeNe, fact, ekeppel, lz1pro
Offline jobber
  • Country: ru
« Reply #252 on: January 14, 2017, 10:23:17 pm »
Hey all!
Technicians at Siglent repair center  ;)
Offline cesarpaz
« Reply #253 on: January 15, 2017, 12:04:09 am »
Hello everyone.
After reading and deciding which spectrum analyzer I buy, I am thinking of buying a Siglent SSA3021X and then converting it into a Siglent SSA3032X. I would like to know what is the opinion of the final result to the users who have made this conversion, is it worth? Give some problems Thank you very much.
Offline ebclr
« Reply #254 on: January 16, 2017, 07:10:32 am »
Until firmware 7.07 flawless, and easy
Offline bozidarms
  • Country: at
« Reply #255 on: January 16, 2017, 08:25:15 am »
Till now, everything OK / marvelous piece of equipment!
Offline radiotech9409
« Reply #256 on: January 16, 2017, 03:04:00 pm »
i got my SSA3021x a couple days ago.  It came with sw 1.2.8.1.  I performed the patch_instruction_new provided by TurboTom.  However, it appears that the latest firmware hides/places the file NSP_system_info.xml somewhere else.  When i performed the back up step for the NSP_system_info, telnet gave a message:  file was not found.  i created one based on turboTom's instruction and wrote it in the system.  However, it seems that the file does not do anything.  Any help is appreciated.
Online Bicurico
  • Country: pt
    • VMA's Satellite Blog
« Reply #257 on: January 16, 2017, 03:11:04 pm »
I would suggest:
1) Do a full backup using the dd command as described earlier in this thread. In worst case scenario, this will allow you to fully restore the flash contents.
2) Do a second backup using the cp command and copy all relevant files/folder, which has been explained, too. This is required to restore the device prior to RMA or firmware upgrade.
3) Take your time to navigate in the telnet shell through all folder, to get yourself familiar with file structure. This is required to avoid problems/worst case scenario.
4) The hack involves renaming three files to dummy names. Once you figure it out, it takes you 1 minute. Then all the hacking fun is gone. Unless you REALLY need the enhanced frequency range, take your time.
5) Learn how to use the instrument before hacking it - that will allow you to check if it is working correctly.
Regards,
Vitor
« Reply #258 on: January 17, 2017, 02:55:50 am »
it seems that you referred to TurboTom's post that pointed to:"Just noticed, rf-loop made it even easier for the newbies... So be sure to cut&paste and save a copy of his post before he deletes it again (as he told he will -- sorry, too late...).  I came a bit late, so I didn't have the chance to read rf-loop's instruction.  I wonder if anyone got a hold of the rf-loop's instruction?
« Reply #259 on: January 17, 2017, 03:44:58 am »
Thanks so much.  Got your instructions.  I will post my progress later.
steverino
  • Guest
« Reply #260 on: January 18, 2017, 02:12:11 am »
Curiosity has me wondering if I missed something in the referenced rf-loop instructions.  Could someone please forward these instructions to me.
Thanks, Steve
Offline pe1oxp
  • ~ Life is too short for QRP ~
« Reply #261 on: January 18, 2017, 07:04:49 am »
That's why I couldn't find the instructions also? I'm also interrested in upgrading my SSA3021x
Can someone help me with these instructions, I have read the thread but not so familiar with Telnet and the used file system
Offline ebclr
« Reply #262 on: January 18, 2017, 01:15:54 pm »
1st step install mobaxterm
Connect the instrument to your router
turn the instrument, and see if they get a IP from your router by dhcp
Use that ip to connect to the instrument
user root
pasword ding1234
Offline rf-loop
« Reply #263 on: January 20, 2017, 11:29:19 am »
<deleted: error>
« Last Edit: January 20, 2017, 08:34:40 pm by rf-loop »
Offline sq6emm
« Reply #264 on: January 20, 2017, 11:39:28 am »
Just for your information.
Ordered SSA3021X on 2016/01/10 in Poland. Distributor said it will be with 1.2.8.1 firmware  :(
Today 2016/01/20 SSA arrived. Unboxed, turned on and...
Voila! 100.01.02.07.07 !
10 minutes later, with NSP...xml file hack and reboot I have SSA3022X with ALL OPTIONS Sta: ON Vaild: Permanent!
Thank you so much EEVBLOG CONTRIBUTORS!:)
Regards,
Dawid SQ6EMM
« Last Edit: January 20, 2017, 12:16:54 pm by sq6emm »
Offline pe1oxp
« Reply #265 on: January 20, 2017, 04:53:57 pm »
Is it possible that some kind people who have this mysterious file can  share it here as message attachment?
Unfortunately I only have a printout of it to read it on my way home in the bus, thought I could save it when I came home from work.
Maybe someone saved the file?
« Last Edit: January 20, 2017, 10:46:40 pm by pe1oxp »
Offline ExplodingLemur
« Reply #266 on: January 20, 2017, 05:41:42 pm »
Can you snap a photo or scan it and put it up on imgur?  We could transcribe it from that.
Offline pe1oxp
« Reply #267 on: January 20, 2017, 05:51:03 pm »
A scan will be possible when there is nobody else who has saved it.
I was just thinking and must have saved it on my computer at work. Otherwise it must be in the Temp-directory. I will have a look on Monday.
The following users thanked this post: rf-loop, ExplodingLemur
Offline kloetpatra
« Reply #268 on: January 20, 2017, 06:28:19 pm »
Am I correct, that only Firmware versions till 1.02.07.07 can be unlocked so far?
Offline rf-loop
« Reply #269 on: January 20, 2017, 06:31:22 pm »
No. Please read this thread more carefully. ;)
« Last Edit: January 21, 2017, 08:42:45 am by rf-loop »
The following users thanked this post: ExplodingLemur
Offline pe1oxp
« Reply #270 on: January 20, 2017, 11:00:54 pm »
I did a quick search and found the information.
MD5 is: f2c4867771222a38f23ebb64d4420d5a
The following users thanked this post: tautech, nugglix, ExplodingLemur, DL4RAJ
Offline 3s1d
« Reply #271 on: January 21, 2017, 12:16:37 am »
Hi everybody,
I read through the whole thread (11pages, took me forever)... It started out great but the end is a bit frustrating.
I'd really like to buy and permanently unlock this device but it will most probably ship with 8.01  :--
As I understand it, nobody who has an unlock device, has had a look into the nsp_data_b file? Its supposed to be a XML file inside an UBI image? Maybe the the options are hidden there?
Greetinx
Juergen
« Reply #272 on: January 21, 2017, 09:26:23 am »
And who would have thought the Chinese author of the .txt file you attached wrote such very good and easy to understand English.  :clap:  ;)
Offline pe1oxp
« Reply #273 on: January 22, 2017, 06:55:22 pm »
My source, the Chinese author forgot some lines in the description, he warned me to be careful
Do not use CHAPTER 2   Or  "full FLASH backup to USB" part in Chapter 8.
ERROR: Missing command lines.  Corrected version is under work.
Please be patient!
The following users thanked this post: videobruce
Offline papousekTopic starter
  • Country: jp
« Reply #274 on: January 31, 2017, 02:29:24 am »
Thanks guys.
i got my SSA3021X for a few months, "UPGRADED" it to 3.2G with full options.
very nice SA, as well as my SDG2042X.  (@cesarpaz, yes, it worth the money
