Dear all,
I need your help because I'm not an expert of linux.
What is the correct syntax for login to SSA3021X (with PuTTYPortable).
I get no response, but I can check the connection by "*IDN?" - there is a response and also I'm able to reboot over LAN.
I have done the last update to firmware SSA3000X_1.2.8.5a_EN (date 180312)
. Unfortunately I have not the possibility like Bandit327, the Back-key is blocked.
Has somebody an idea, ore must I go over the internal serial-port?
You need use TELNET!
But please if you do not know what you are doing then study before you do anything. When you have root then with mistakes you can mess whole SA.
PuTTYtel client you can find here
https://www.chiark.greenend.org.uk/~sgtatham/putty/latest.htmlAnd there you download 32 or 64 bit version (a Telnet-only client)
32-bit: puttytel.exe
64-bit: puttytel.exe
(and for tracking some possible mistakes turn also log on so that it log all your work to log file.)
Also keep care you follow right instructions and not all fake informations here and there.
Remember, if you are not sure what you do then do not. Golden rule: First brain - then muscle.
This is how SSA3000X answer when it see your terminal. If you do not see this kind of terminal screen (coming from SA) when you connect terminal then you are doing wrong or something is wrong. (Terminal..what terminal...you have sopme kind of PC, you do not have real terminal (exept if you have), you have Windows PC or Kylin PC or whatever OS PC somehow emulating real terminal)
Connection protocol is
Telnet and telnet port is 23 (PuTTYtel default) and IP address is how you set in SA and then also in PuTTY settings correspondingly.
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org am335x-evm
Arago 2013.05 am335x-evm
am335x-evm login:
Read carefully this msg
https://www.eevblog.com/forum/testgear/hack-of-sigllent-spectrum-analyzer-ssa3021x/msg1251608/#msg1251608and all what you can find here (including links) and if you find some instructions then adjust some parts of instructions with this message (because something have bit changed after V05 instructions.)
And remember that right use of copypaste is your friend for avoid any typing errors in command lines. Worst case some mistake/error may be fatal.
