Author Topic: Hack of Sigllent spectrum analyzer ssa3021X?  (Read 438561 times)
explozz and 2 Guests are viewing this topic.
Offline benishor
Re: Hack of Sigllent spectrum analyzer ssa3021X?
« Reply #1000 on: April 27, 2022, 07:46:25 am »
Hi there,
Lurker here. Sorry to revive the thread. I am considering getting a SSA3021X Plus and I was wondering what is the current state of things? Is there still an upgrade door available for the SA? Also, is there a way to get a discount when buying from Europe?
Thank you!
Offline epsilon888
« Reply #1001 on: May 10, 2022, 06:04:37 pm »
Hi all. I have a SSA3021X with firmware version 2.1.1.1. I guess it's firmware for the Plus version, as there is options for touch screen but not a physcially touch screen. There is also an integrated webserver. I can't get any connection via LAN and Telnet. Now my question: Can I "upgrade" this scope to 3.2GHz? If so, how? Thanks in advance.
The following users thanked this post: ThomasM...
Offline ThomasM...
« Reply #1002 on: May 11, 2022, 06:33:25 pm »
... the script works great with FW: 1.3.9.6 for my SSA3021(NON+) which is now a fully modified SSA3021 all options permanet
Great Job
Thanks and regards from Munich  :)
Offline epsilon888
« Reply #1003 on: May 13, 2022, 03:43:24 pm »
Hi. Did you installed an older firmware than default in the instrument? If so, what was your default firmware? Thanks.
Offline ThomasM...
« Reply #1004 on: May 15, 2022, 07:25:58 pm »
Hi, modification has been done with 1.3.9.6, which was updatet from initial version 1.3.9.5 @ delivery.
Finally after modification updated to 1.3.9.7
Regards
Thomas
« Last Edit: May 15, 2022, 07:28:26 pm by ThomasM... »
Offline benishor
« Reply #1005 on: May 27, 2022, 12:48:37 pm »
Hi all,
I got a SSA3021X plus running the 3.2.2.5.0 firmware. Is there a way to increase the span to 3.2GHz? I looked through the forum posts but got lost in a lot of non plus messages.
Thank you!
Offline benishor
« Reply #1006 on: May 28, 2022, 05:34:53 pm »
Just wanted to confirm that I managed to unlock it (thanks @cubitus), so the upgrade path for brand new SSA3021X Plus with 3.2.2.5.0 is still there.
Offline epsilon888
« Reply #1007 on: May 29, 2022, 09:34:25 pm »
Hi. Can you tell us how you did it in more detail? Thanks.
Offline benishor
« Reply #1008 on: June 12, 2022, 06:51:10 am »
I will quote the instructions I received which were good for me:
TELNET
 IP web browser of the SSA3021
- telnet to port 5024 (SCPI) and send the command 'DEBTTT' (this should start a telnet server on port 23)
- telnet to port 23 and log in as 'root', pw 'ding1234
at first ceca just allows you to have all the options #428
https://www.eevblog.com/forum/testgear/hack-of-sigllent-spectrum-analyzer-ssa3021x/425/
to go further : #1620
https://www.eevblog.com/forum/testgear/siglent-ssa3000x-spectrum-analyzers/msg3563577/#msg3563577
The following users thanked this post: epsilon888
Offline epsilon888
« Reply #1009 on: June 15, 2022, 05:12:07 am »
 :) Thanks. I will try this method.
Offline nilswe
« Reply #1010 on: June 19, 2022, 08:49:31 pm »
Hi all,
Do you have to do something different as described in #1620 ? Did you flash it with the new SVA V3.2.2.5.0 or with the SVA 3.2.2.4.0 Firmware?
Did you deviate from something else?
I Also got a new SSA3021X Plus with the 3.2.2.5.0 FW installed.
Sorry, that I'm asking  I'm a little nervous
Tanks  :)
Online tv84
  • Country: pt
« Reply #1011 on: June 19, 2022, 09:17:13 pm »
Again for the latest version...
For those that have the v3.2.2.5.0 version, you can download the SVA1000X_V3.2.2.5.0 from Siglent site and do this patch using an hexeditor. After that, flash the firmware in your SSAX+ and you'll have a SVA.
PS: Combine this with previous instructions as it will only replace some parts.
The following users thanked this post: nilswe
Offline nilswe
« Reply #1012 on: June 20, 2022, 08:24:37 am »
Thank you so much!  :)
Offline jhormilla
« Reply #1013 on: July 05, 2022, 06:43:15 am »
Regards
Thomas
Mine was at 1.3.9.8, dropped it down to 1.3.9.6 and was able to telnet on port 10101 with the file SSA3000X_telnet listed by tv84,
I didn't have to use a login or pw, when I tried it didn't recognize the commands, but it was displaying the Arago project logo and seem to be responding, I then typed in the following commands.
cd /
cp -R /usr/bin/siglent/usr/backup /usr/bin/siglent/usr/mass_storage/U-disk0/SA-backup
cp -R /usr/bin/siglent/firmdata0 /usr/bin/siglent/usr/mass_storage/U-disk0/SA-firmdata0
the progress bar on the SSA stopped at 60% so I waited about 20 minutes, I then pulled the USB out and re started the SSA, it was not bricked, then read the USB stick on the PC and the two files were in there. I tried the whole procedure again and this time after the two files were written to the USB stick by the SSA using SSA3000X_telnet I entered the following commands,
cd /
mount -o remount,rw /dev/ubi2_0 /usr/bin/siglent/firmdata0
cd /usr/bin/siglent/firmdata0
mv NSP_sn_bandwidth.xml NSP_sn_bandwidthx.xml
cd /
cd /usr/bin/siglent/usr/backup
cd /
sync
exit
didn't get any errors but after re starting the SSA it turned on just fine but no upgrades.  |O
Any help would be appreciated.
Offline ThomasM...
« Reply #1014 on: July 05, 2022, 07:17:23 pm »
Regards
Thomas
cd /
cd /
cd /
cd /
sync
exit
Root and PW is necessary
Offline jhormilla
« Reply #1015 on: July 05, 2022, 07:32:49 pm »
Got it figured out thanks to Thomas. It's running with 1.3.9.8  :-+
Thank you for all the help guys,
Offline hafrse
« Reply #1016 on: July 11, 2022, 01:50:08 pm »
Hello,
is  it possible to patch a ssa3032X-R to be a ssa3075X-R  ? if so, where I can find the information ,  thanks
Offline tomud
« Reply #1017 on: July 19, 2022, 02:44:50 pm »
Someone asked about the EMCView software once, maybe the attachment will be useful to someone who has a spectrum analyzer with the serial number XXXX (and not only) :P
Edit by gnif: Attachment removed, we are not a cracking/warez site.
« Last Edit: July 21, 2022, 10:09:39 am by gnif »
For every complex problem, there is a solution that is simple neat and wrong...
Offline Bicurico
  • Country: pt
    • VMA's Satellite Blog
« Reply #1018 on: July 21, 2022, 09:37:00 am »
I don't consider it reasonable to publish a keygen for a software that is still in development and being sold.
Why harm this company? Should they rather close business and stop furher development?
Offline tomud
« Reply #1019 on: July 21, 2022, 01:30:49 pm »
The company will buy such software because it needs support, a few amateurs hacking a Siglent device would never buy it and it would not hurt the software manufacturer (the company does not hack spectrum analyzers to have a serial number XXXXX). Hacking Siglent devices - theoretically, we also harm the device manufacturer. How is cracked software running on a spectrum analyzer different from software running on a PC ? (symptoms of hypocrisy ?)
Looking at it differently - an amateur electronics engineer who builds do-it-yourself constructions can get to know the software (as well as EMI / EMC issues) better, which may translate into purchasing software in the company he works for.
For example, at home I use hacked devices such as Siglent, Rigol etc. as well as such software (I have a limited budget for DIY), but in my company I already have legal versions of devices and software (The company earns more because I buy two devices, one cheaper for my home, the other more expensive for my business).
« Last Edit: July 21, 2022, 02:42:39 pm by tomud »
Offline RyanBoggs
« Reply #1020 on: July 21, 2022, 10:04:47 pm »
I have the exact same issue.  Version 2.1.1.1 seems to be a version shipping with new units that isn't available publicly on Siglent's website. My unit seems to indicate that this firmware update was from October 11, 2021.
It won't seem to let me downgrade to a 1.x.x.x version either. No telnet connection for me, though I can get a ping.  I am wondering if Siglent is trying to permanently patch new units to be unhackable through the currently known means and is holding on to the new firmware to prevent people from messing around with it.
Online RoV
« Reply #1021 on: July 22, 2022, 08:56:55 am »
Did you try this one? https://www.eevblog.com/forum/testgear/siglent-ssa3000x-spectrum-analyzers/msg4143817/?topicseen#msg4143817
Offline RyanBoggs
« Reply #1022 on: July 22, 2022, 04:52:06 pm »
Yes I did.  No telnet on port 5024 either.
Offline Bicurico
  • Country: pt
« Reply #1023 on: July 22, 2022, 05:37:58 pm »
You must be doing something wrong then.
This is the SCPI port and it must work.
Offline RyanBoggs
« Reply #1024 on: July 22, 2022, 06:39:36 pm »
I figured I might be.  It's been a while since I have done anything with telnet like this and it isn't my specialty.  I tried it with both PuTTY and the Windows built-in telnet.
