My free gift of choice at HF is the DMM. I've given away quite a few, but I have 8 of the current red versions. I just tested 8 of them against an LM399 voltage reference. I don't know the actual voltage, but my HP 3478A says is is 6.9113 V.
Edit: I used a couple of 5% metal film resistors to make a 68K:1k divider for the 200 mV range.
#90899 #1 6.92 V +0.14% 99.2 mV +0.02%
#90899 #2 6.93 V +0.29% 99.0 mV -0.18%
#92020 #3 6.88 V -0.043% 98.8 mV -0.38%
#69096 #4 6.91 V 0.0% 99.2 mV +0.02%
#90899 #5 6.89 V -0.29% 98.9 mV -0.28%
#98025 #6 6.96 V + 0.79% 99.3 mV +0.13%
#90899 #7 6.91 V 0.0% 98.8 mV -0.38%
#90899 #8 6.88 V -0.43% 98.8 mV -0.38%
3478A 6.9113 V 99.174 mV
There is a trimmer for adjusting the voltage, so I adjusted a couple of older ones I use on a regular basis to read 6.91 V. I'm going to leave the red ones alone and test them again later. These were sitting in an unheated space. I let them warm up, but I'll let them sit a warmer space for the next test.
These all have the original batteries and some may be up to 3 years old. Claimed accuracy is 1% + 1 digit. So all are well within spec.
I suspect that the AC performance is not as good, but I'll leave that test to another day. I've got a DMMCheck Plus on order, so I'll make more tests when it arrives.
My reason for doing this is my concern that the voltnut aberration latent in many of us leads beginners on tight budgets to spend more on DMMs than they should. If you're building things using 5% resistors and 10% capacitors you don't need a 0.01% DMM.
Edit: added HF item numbers.
Edit: For the benefit of non-USA readers:
https://www.harborfreight.com/7-function-digital-multimeter-90899.html
