SSG5083A 13.6 GHz
SSG5085A 20 GHz.
![](https://www.siglent.com/u_file/product/21_04_08/2.png)
![](https://www.siglent.com/u_file/product/21_04_08/5.png)
Release 26 Sept 2022
SSG5083A 9 k ~ 13.6 GHz
$16,210
SSG5085A 9 k ~ 20 GHz
$19,070
Options
SSG5080A-PU Pulse modulation (software license)
SSG5080A-PT Pulse train generator (software license)
SSG5080A-LP 110dB Attenuator module (hardware, assembled and calibrated in factory only)
Level setting range: -130 dBm ~ +25 dBm
Output frequency resolution up to 0.1 Hz
Phase noise <-120 dBc/Hz@1 GHz, offset 20 kHz (typical value)
Amplitude accuracy ≤0.7 dB (typical value)
Support AM/FM/PM analog modulation, support internal and external modulation methods
Support pulse modulation function (optional), pulse train generator, user-defined pulse sequence (optional)
Power meter control kit for and line loss correction
Supports web remote control
5-inch capacitive touch screen
Rich communication interface: standard USB-HOST, USB DEVICE (USB-TMC), LAN (VXI-11, Socket, Telnet), optional GPIB
English datasheet:
https://int.siglent.com/u_file/download/22_09_23/SSG5000A_Datasheet_DS0805A_EN02B.pdfhttps://int.siglent.com/products-overview/ssg5000a/https://siglentna.com/rf-generators/ssg5000a-series-rf-signal-generator/https://www.siglenteu.com/rf-generators/ssg5000a-series-rf-signal-generator/
