Had another check, resoldering and desoldering, cleaning and checking again. Eventually, I found a trace behind the Nickle spring was open (with some trace of copper oxide here and there). Cleaned with acetone (have no alcohol in stock, no IPA as well - had run out and I didn't do panic shopping), cut the unneeded part of the contacts (to avoid bending stress), and soldered the contact/trace and wires, tidied everything up again. Now in perfect order, bingo!
