Author Topic: GW-Instek GPE-2323 / RS Pro RPE-2323 power supply review  (Read 6306 times)
Offline DeckertTopic starter
    • TechBench
« on: July 12, 2017, 11:01:14 pm »
Hi guys,
I've seen a few questions about it on the forum, so I did a quick-ish review of the GPE-2323 power supply at the link down below. I have the RS Pro unit, since shipping by other means to my country is a nightmare in terms of consistency. I'll hopefully complete part 2 (a teardown / look inside) over the coming weekend, so let me know if there are other questions or things you want to see inside.
--deckert
« Last Edit: July 12, 2017, 11:26:12 pm by Deckert »
The following users thanked this post: lem_ix, auclairD, arvidb
Offline Daruosha
  • Country: ir
Re: GW-Instek GPE-2323 / RS Pro RPE-2323 power supply review
« Reply #1 on: July 14, 2017, 04:10:17 pm »
Thanks for your nice review.  Is there a teardown video as well? I'm struggling to buy the 4 channel version of this power supply, but I am not sure about the build quality (transformer, caps, ...).
I'd appreciate if you could bother with taking it apart and show us the inside.
    • TechBench
« Reply #2 on: July 14, 2017, 11:17:43 pm »
Yes, teardown video coming soon! Need to see what's inside it myself :-)
--deckert
The following users thanked this post: Daruosha
    • TechBench
« Reply #3 on: July 19, 2017, 07:31:35 am »
As promised, a teardown of this power supply:
--deckert
The following users thanked this post: lem_ix, Daruosha, auclairD, arvidb
Offline Coceth
« Reply #4 on: October 03, 2017, 10:32:24 am »
Very nice review + teardown. The GPE-2323 has a lot going for it (inexpensive, output on/off switch, 1mA resolution). Do you wish you had a third and forth output, or are the two outputs adequate?
Offline auclairD
« Reply #5 on: November 05, 2017, 03:04:12 pm »
Thank you Deckert! This thourough review convinced me to make the move on this unit. I was looking for a solid supply capable of 48v - 54v and this one looks like a quality build, more than just good appearance.
    • TechBench
« Reply #6 on: February 11, 2018, 09:13:25 pm »
Hi - one last update on this supply.
I made a very short (2 minute) video on how to reduce the fan noise by adding a series resistor to the fan. It reduced the fan noise significantly without incurring too much penalty in terms of temperature rise (measured a max of 60 degrees C on the main heat-sink at full load on both channels).
--deckert
The following users thanked this post: arvidb
