I'm thinking about getting an UNI-T UT208 clamp meter.
I see that it does have an inrush current button, however the downloaded manual is not very informative about it.
As I don't have physical access to it to see how it works before buying, is there anyone that can shed some light about the inrush current functionality of this meter ?
Also any info about issues with this meter that are not obvious from the specs would be appreciated.
Thank You.
