Hi Guys
I have a KP184 and need to verify the current accuracy for some PCB fuses.
I have only used the KP184 a couple of times, and only used the load testing, using the constant current function.
I need to do a couple of “time current curves” (melting fuse time curves) with constant current load over time.
Any suggest to how I approach this task ?
