Hello!
Sorry to repeat the post, I think I put it in the wrong place.
I have a problem with an Promax OD-581 with vertical chanel accuracy...
This Oscilloscope is a clone of GW-Instek GDS-800 series...
I Only need service manual in order to run the auto cal function that the instrument have.
It uses a BNC in the rear panel to do the AUTOCAL.
But Promax in Spain only do calibrate the instruments if I send It to them..
So if someone have the Service Manual PDF and send it to me, I will thank You forever
Regards
Manuel
