Author Topic: GW Instek GDS-2000E teardown /short review, comparison with Rigol DS2000(A)  (Read 21833 times)
Offline wraperTopic starter
  • Country: lv
Pin 10 and 11 in 6518 amplifier is SDIO and SCLK
Not any kind of differential analog output
Hmm, but they have aux output. though it's not apparent if is used.
  • Country: lv
This is important difference.
Input MUX + 180 degree clock phase shift between internal 2 ADC.
What prevents you from doing the phase shift in ADC08DL502?
Offline rf-loop
On the 2 channel versions it remains 1 GSPS regardless how many channels are used.
Do they have two ADC08DL502 chip also in 2 channel models so that both channels can use separate ADC chip?
With one ADC08DL502 can not do 2 channel 1GSa/s.
How they do true 1GSa/s even for one channel with one ADC08DL502 is also big question.
Offline rf-loop
I have not seen this function in ADC08DL502  One common clock input to both ADC.
Inside ADC08D500 there is also one common clock to to both adc but inside chipe there is selectable 180 degree phase shift. In this DES operation mode also phase shift is internally calibrated.
The ADC08D500 also includes an automatic clock phase background calibration feature which can be used in
DES mode to automatically and continuously adjust the clock phase of the I and Q channel. This feature
removes the need to adjust the clock phase setting manually and provides optimal Dual-Edge Sampling ENOB
performance
ADC08DL502 do not have at all this DES mode (Internal interleave mode)
And then, how you do 1GSa/s  if you have selected CH1 and CH2 for use and both have 1GSa/s and how it is done if CH1 and CH3 is selected and then both have 1GSa/s.
(this is why ask 2 input from 4 possible combinations and your result was that what ever 2 is selected there is 1GSa/s for both selected cannels.)
I want only know how they do this. (I have not claimed they can not do)
« Last Edit: May 08, 2016, 09:52:42 am by rf-loop »
  • Country: lv
You do have 2 independent ADCs in it. Shift the clocks with FPGA.
EDIT, I had a brainfuck, following is not true.
I've done some poking measurements. There is external muxing going on. Even more funny, When you have only ch 4 enabled, signal goes to the both inputs of the ADC on the right(on the picture I provided) which is located above the first 2 channels  :scared:
Even more funny, when you have CH1 and CH4 enabled. Signal from CH4 goes to the right ADC, CH1 to the left ADC  :-DD.
« Last Edit: May 08, 2016, 10:51:53 am by wraper »
Offline rf-loop
For clarify: Do you mean 2 independend ADC chips (what both include 2 ADC,)
Interesting case...very interesting.
If Signal from example CH1 (alone in use)  go to to two separate ADC chip, then there can phase shift but it leads many problems what need solve related to clock timing accuracy (jitter/phase noise/phase accuracy). Then also lot of do with different analog side signal pathways skev. Also amplitudes need really match. And in this case there is not inter chip automatic calibrations for help matching two interleaved ADC's in separate chips)
« Last Edit: May 08, 2016, 10:11:36 am by rf-loop »
  • Country: lv
Hmm, probably I had some brainfuck, measuring this again. EDIT, it certainly was.
« Last Edit: May 08, 2016, 10:31:35 am by wraper »
Online nctnico
As far as I can see the VGAs (LMH6518) drive each ADC so it is possible to compensate for amplitude differences before each signal goes into the ADC. For this purpose the GDS2000E has a special calibrator output which is used during the self calibration/adjustment procedure. The frequencies are too low to have serious problems with skew (A 1ns delay needs about 30cm of trace length).  I think they use the transistors/diodes in the circuit to do the signal routing. The 8 pin SOIC is an AD8510 JFET amplifier to amplify/buffer the signal from the input attenuator. From there the signal goes into various transistors/diodes which seem to have no appearant other function. In a more classical oscilloscope design the output from the JFET amplifier would go straight into the VGA but it doesn't. So by logic deduction the multiplexing must happen by the extra transistors/diodes. It could be a simple JFET switch approach:
edit: The 2SK508 JFET has package marking K52 (one of the transistors visible in the photos) so that is a pretty solid support for the discrete multiplexer theory.
« Last Edit: May 08, 2016, 11:21:26 am by nctnico »
  • Country: lv
After measuring back and forth, in the end there appears no analog switching going on. Channels are directly fed into the ADCs. Some fishy wizardry is going on. Maybe they are overclocking ADCs? BTW changing sample rate or switching off the channels does not seem to affect ADC temperature on the thermal imager. One ADC is about 50oC, Another 54oC That with cover removed of course.
Offline rf-loop
Ok, perhaps it is solved or guessed  what they perhaps do. (when I have been writing @wraper  last message make this my comment too optimistic)
IF they do "Ping-Pong" interleaving with two separate ADC.
Do you think 1ns delay there on the board in practice is 30cm... perhaps I'm also Santa Claus.
Time skew between two pingpong interleaved ADC is - how I say it nicely - still critical.
1ns is long time! It is whole 360 degree in 1GSa/s system.
Take very extremely simplified thinking, so that all can think it just calculating in head without more math. Lets think there 1GSa/s samplerate done with two 500MSa/s PingPong interleaved ADC and system itself is ideal and after one input signal goes ideally to both of these clocked ideally and ADC's linearity and amplitude etc all is ideally matched and they have ideal 180 degree phase shift.
Now, 200MHz scope rough risetime is 2ns. For simplify lets think there is 256 FS but this input signal make linear 200 ADC step change  in 2ns. So, 100step in 1ns.  In 100ps it change 10 step etc... this time error is directly translated to ADC sample point level error.
Do you still think time skev do not mean. If there is some kind of calibration for this, how it adjust these picoseconds. Programmable delay line?    Static delay is simple case. But also clocking separate ADC chips without any meaningful jitter is bit challenging when it need do cheap.
« Last Edit: May 08, 2016, 12:14:45 pm by rf-loop »
Online nctnico
The ADC08DL502 ADCs have a clock phase adjust control in 0.2ps steps.
Offline siggi
From the data sheet it looks like there are ADC registers that allow skewing the sample clock. The range mentioned is 2.1ns - would that be sufficient?
If you have a logic analyzer handy, maybe you could sniff the serial input to the ADCs?
  • Country: lv
I already spent more time than I should on figuring out this. Also, I'll be in another city for the whole next week starting from tomorrow, and actually don't have much of free time because I need to finish one project.
Poking here and there too much vastly increase the chances to kill this scope too.
  • Country: lv
Sampling rate doesn't drop unless 3 channels are enabled simultaneously. So considering signal measurements I made on ADC inputs, my best bet is overclocked ADCs.
CH1 enabled, 1 GSPS
CH 1 & 2 enabled, 1 GSPS
CH 1, 2, 3 enabled, 500 MSPS
The fact is, Rigol and GW instek are interleaving multiple slow ADCs in their older models - GDS-1000A/A-U and DS1000E.
« Last Edit: May 08, 2016, 01:37:27 pm by wraper »
Offline fanOfeeDIY
  • Country: jp
    • YouTube Channel
I have now readed several times Ti data sheets about 08D500, 08D502 and 08DL502
I have one question. How they have done this 1GSa/s.
http://www.ti.com/lit/ds/symlink/adc08d500.pdf     2x500MSa/s  or 1GSa/s interleaved.
This is only what have interleaved mode for 1GSa/s if read Ti data sheets about these ADC versions.
http://www.ti.com/lit/ds/symlink/adc08d502.pdf     2x500MSa/s
http://www.ti.com/lit/ds/symlink/adc08dl502.pdf    2x500MSa/s
This is purely my guest and just my imagination.
I have a feeling that they bought all three of the ADCs, 08D500, 08D502 and 08DL502 and, and, and :)
they tried the DES enable bit  on address Dh and found that the bit enables DES on even 08DL502.
It is possible if TI is using the same die, and selling them differently with yield inspection.
The one passed the DES will be sold as 08D500 and the one did not pass or did not check for reducing the cost of qa as 08DL502.
Then GW instek might buying many of 08DL502 and select by them self which DES works.
Normally this is difficult to be allowed when you work as the product manager in inflexible company, but the world could be flexible.
Online nctnico
I agree. TI recommends using a copper area as a heatsink but GW Instek choose to put relatively large heatsinks on top of the ADCs.
  • Country: lv
I rather suspect that they found that dual 1 GSPS ADC from Ti uses the same die as this 2x 500 MSPS one.
They must be overclocking, otherwise I don't understand how do they get 1 GSPS on 2 channels simultaneously while using one ADC (CH 1&2 or CH 3&4 scenario).
Offline rf-loop
So or so. All is possible. But also it IS possible to do system where is total 4 channel.
Two ADC chip what both have two internal  500MSa/s ADC (without internal inteleaving feature and both internals have same clock)
And so that what ever 2 channel is in use it is 1GSa/s for both selected channel.
If then turn on what ever one channel more it drops to 500MSa/s for all channels in use.
This need external Mux and CH select analog switch system before ADC and when it is in 1GSa/s mode other ADC chip need clocked interleaved and because this is in principle two ADC pingpong inteleaving timing is quite simple. There is just two these systems.  But if it is like this then it need that also 2 channel model have still 2 these ADC.
Idea is that in two channel mode other chip get inverse clock (180 degree phase and this can do even with clock delay adjustment inside chip) and during cal procedure fine adjusted for enough low signal skev (related to clock).
If both chips have ADC A and B then A inputs connected together and B inputs connected together.
Then example one Ch input connected to this A  and what ever other Ch  input connected to this B.
If one Ch alone then just connected alone to ADC input link A or B.
If more than 2 channel then links A and B need open and both chips clock to same phase.
It works but why do this... (IF they have done something like this)
(If they have found that internally chips are same but not factory quaranteed... this is totally other and much much more easy (and cheap) case)
« Last Edit: May 08, 2016, 02:21:33 pm by rf-loop »
Offline Krisztián
  • Country: hu
Re: GW Instek GDS-2000E teardown /short review, comparison with Rigol DS2000(A)
« Reply #43 on: December 04, 2021, 06:08:39 pm »
Could somebody please check his/her GDS-2000E series oscilloscope if it also has that strange DC error? Seems to me a thermal error. All four channels behave the same on my GDS-2104E. Offset range is excellent on that scope but top of a 5Vpp 10Hz signal at 5ms/div timebase is ...
On the screenshot Yelow trace is top of the 3,2Vpp function generator sync signal for trigger source. Blue trace signal is  top of 5Vpp 10Hz. Both trace at 50mV/div sensitivity. The error seems proportional to amplitude of supplied input square wave.
Checked the scope with another type (analog) funcgen and the error is the same, so my function gens must be outputting clean square.
Checked both of my funcgens outputs with my Hitachi VC-6145 DSO and that scope does not has this type of error.
Of course you'll have to turn the offset down to -5V on both channels to see the top of the squares.
Thanks for advance for checking that on your scope!
« Last Edit: December 04, 2021, 06:15:27 pm by Krisztián »
Online nctnico
« Reply #44 on: December 04, 2021, 06:43:41 pm »
Have you tried to run the self calibration?
Offline Krisztián
  • Country: hu
« Reply #45 on: December 04, 2021, 07:25:44 pm »
Thanks for the question, but I was very surprised by it.
Selfcal only used for compensating permanent DC offset. This is not a DC offset.
I used a short BNC-BNC coax cable for that 'measurement'. I think this is a sign of poorly designed input stage. That's why some of the Tektronix scopes using a termally excellent cascomp input stage.
My Hitachi scope has an excellent symetrical JFET input stage.
Could you please test it on your scope?
That's is inherent. It's not the ADC. It's not the offset circuit. It's simply error of the discrete input frontend.
I bet your scope will behave the same like mine.
Offline Krisztián
  • Country: hu
« Reply #46 on: December 04, 2021, 08:40:41 pm »
Was worng. Selfcal is for vertical sensitivity calibration. SPC is used for compensating permanent DC offset.
After selfcal the error is still the same.
This is inherent to input stage circuit.... :( Maybe changing some resitors to low tempco ones and cascoding BJT-s would help.
Offline Krisztián
  • Country: hu
« Reply #47 on: December 04, 2021, 09:13:40 pm »
From top to bottom traces showing top of:
- 10Vp-p square wave [at 100mV/div]
- 5Vp-p square wave [at 50mV/div]
- 1Vp-p square wave [at 10mV/div]
Error is totally proportional to input level. This is a thermal error.
Unfortunatelly nothing to do with SPC or Selfcal.
« Last Edit: December 04, 2021, 10:22:44 pm by Krisztián »
Online nctnico
« Reply #48 on: December 05, 2021, 12:08:13 am »
I think you should first check what the error percentage is of what you are seeing and then compare to the specs. You can expect the DC error of an oscilloscope to be in the ballpark of 1% to 2%. 1% of 5V is 50mV so seeing an offset error of 1 division at 50mV while looking at a 5Vpp signal doesn't seem out of the ordinary to me.
Offline Krisztián
  • Country: hu
« Reply #49 on: December 05, 2021, 12:58:40 am »
Yes, you're right. That's within specification limit.
I wanted to use this scope to average 8-bit digitized waveforms on a PC so I can effectively see more bits of information. But since (at least for me) the error is so 'large' with this scope, it can't be used for that.
