Author Topic: New GW Instek GDS-2000E oscilloscope released  (Read 83593 times)
Offline HydrawerkTopic starter
Re: New GW Instek GDS-2000E oscilloscope released
« Reply #125 on: March 18, 2016, 12:06:16 am »
I tried this GDS-2000E scope on a trade fair. It is probably OK for the price. There are some quirks. The <- -> buttons work only in Search mode. The scope seems to be responsive.
Offline PigSpark
« Reply #126 on: March 21, 2016, 05:00:27 pm »
Firmware 1.24 has been released.
« Reply #127 on: March 22, 2016, 08:57:38 am »
Welcome to the forum.
FW link please.
Offline PigSpark
« Reply #128 on: March 22, 2016, 10:09:58 am »
Offline markone
« Reply #129 on: March 22, 2016, 12:39:10 pm »
FW link please.
Hi Tautech, do you own a GDS-2000E scope ?
Offline markone
« Reply #130 on: March 24, 2016, 12:49:12 am »
A couple of days ago i contacted GW asking information about dual display FFT mode function, they promptly informed me that the related APP was just uploaded under GDS-2000E download page :
http://www.gwinstek.com/en-GB/products/Oscilloscopes/Digital_Storage_Oscilloscopes/GDS-2000E
Just installed, it works good.
« Last Edit: March 24, 2016, 12:51:59 am by markone »
Online nctnico
« Reply #131 on: March 24, 2016, 03:35:51 pm »
Cool! Scrolling the source channel up or down also works but this is much better! I did not have the time to look for other new features in the firmware. These software apps (plugins) are interesting BTW. It would be great if GW Instek released some kind of SDK and specification so people could write their own. I don't even care whether they provide any kind of support for it; I don't mind a bit of trial and error because the benefit is huge.
« Last Edit: March 24, 2016, 03:39:46 pm by nctnico »
Offline markone
« Reply #132 on: March 25, 2016, 12:26:46 am »
It works if the waveform does not touch and go over screen edges, otherwise signal start to clip and harmonics appear on the spectrum.
Online nctnico
« Reply #133 on: March 25, 2016, 12:49:32 am »
That is true. I forgot to add 'when the acquisition is stopped'!
Offline Vytautas
« Reply #134 on: March 29, 2016, 06:33:26 am »
The FFT app you downloaded is not available anymore for download. Removed?
Offline PigSpark
« Reply #135 on: March 29, 2016, 09:00:39 am »
And the 1.24 firmware update as well  :wtf:
I have emailed them about a bug I discovered when viewing a simple trace.
3 MHz sine wave 10 Vpp, with intensity set to 0% the waveform is viewable when I set the timebase to 50 ns the trace disappears, you then have to adjust the intensity to 10% to see it.
This happens on all 4 channels.
Online nctnico
« Reply #136 on: March 29, 2016, 10:38:30 am »
I don't think that is a bug but just how the intensity grading works. I have the intensity set to 50% on my GDS2000E.
Still I agree it is weird they pulled the new files from their website. Maybe they want to push out a newer version with some more additions.
Offline PigSpark
« Reply #137 on: March 30, 2016, 09:51:51 am »
Just had an email from GW saying they will renew the firmware mid April to resolve the issue I found.  :-+
Offline Vytautas
« Reply #138 on: March 30, 2016, 08:16:09 pm »
Good. I am waiting my ordered GDS-2072E to replace my old and faulty Rigol DS1052E and wonder what firmware version it will have installed.
Offline Vytautas
« Reply #139 on: March 31, 2016, 12:25:00 pm »
Correction.
The FFT app and 1.24 upgrade are available for download in the GWInstek page, you just have to login.
Online nctnico
« Reply #140 on: March 31, 2016, 02:10:59 pm »
>:( I hate needing to login to see/download firmware updates!
Offline Vytautas
« Reply #141 on: April 17, 2016, 01:26:55 pm »
Just received my GDS-2072E. After playing with it for a short time, I can say I am very happy with the device.
Very responsive. And full of features - segmented memory up to 29000 segments, digital filtering, event search, gated measurement capability, fast FFT (and in a separate window after the update), Autoset extremely fast. Also, 1Gs/s PER CHANNEL, memory 10Ms PER CHANNEL, 120000 wfms/s update. Brilliant. So far, have not found any bugs (though, frankly, have used it for a couple of hours yet). So far, very happy.
Offline Vytautas
« Reply #142 on: April 20, 2016, 06:37:32 pm »
Here are the screenshots showing visual persistence performance of my GDS-2072E at different levels of intensity. Pretty good.
Offline Vytautas
« Reply #143 on: April 20, 2016, 08:00:11 pm »
And another, pretty fortunate discovery!
The specification chart published in the manual for the GDS-2072E says that when the vertical resolution is set to 1mV/div, the bandwidth is automatically set to 20MHz. This is not true, fortunately! Here are the screenshots showing that even in 1mV/div full bandwidth is possible! Beauty!
Online wraper
  • Country: lv
« Reply #144 on: April 20, 2016, 08:19:37 pm »
You should check this with some real signal. 20MHz is a bandwidth limiter. I don't think it would be smart to make this setting jumping from 20 MHz to full, while changing the vertical resolution. So your "full" might be only "20MHz + a bit above" at this vertical resolution.
Offline Vytautas
« Reply #145 on: April 20, 2016, 08:45:23 pm »
Here are two shots, just hooked up to a power supply, showing noise (of course, the ground lead is crap for measuring noise, but anyway, the shots show full bandwidth IS available in 1mV/div.) The older models had full bandwidth simply disabled, when in 1mV/div. It is not disabled in this model. Probably what could have happened, is that they just forgot to delete that note from the manual, which has no doubt been prepared by adjusting a previous version of a manual. I wrote GWInstek an inquiry about this. Lets see, what they will say.
« Last Edit: April 20, 2016, 09:42:07 pm by Vytautas »
Offline Vytautas
« Reply #146 on: April 21, 2016, 07:51:57 am »
I just received an answer from GWInstek. They confirmed my finding. Here is what they said: „Dear Vytautas, Thank you very much for your inputs. You are right, the BW does not limit to 20 Mhz, and we will modify our manual accordingly.“
Offline PigSpark
« Reply #147 on: April 21, 2016, 05:18:03 pm »
Just been sent a beta 3 release of firmware 1.25 to try and it fixed the problem I had with the waveform intensity.  :)
The following users thanked this post: wblock
Offline 4cx10000
« Reply #148 on: April 21, 2016, 07:30:55 pm »
Just a short question that may not belong in this thread. Since there are Europeans here, where would buy the GDS-2000? Got my eyes on an GDS-2204E.
Online nctnico
« Reply #149 on: April 21, 2016, 07:37:11 pm »
GW Instek has a European office (located in the Netherlands) so you could ask them to recommend a dealer: sales@gw-instek.eu
