Some quick replies for now. I can likely look more closely on the weekend.
- I like the idea of treating this as a secondary meter. I recently acquired a couple of 4.5 digit DMMs (Fluke 8600A and 8050A) one of which will likely become my main bench meter.
- I looked at the LCD. It sits pretty close to the display board, connected to it via a pair of rubber zebra connectors. I don't think there's any place to mount a LED backlight behind it without adding a spacer, which would require a source for longer zebra strips. On the other hand, a couple of LEDs as a side light looks plausible.
- I found a couple of 7106 datasheets. That should be enough to trace circuits functionally. (Though that might have to wait until I retire).
- Yes, 0.25 V and 2.5 V are at the low end of their respective ranges. That's because the voltage reference I happen to have is based on a 2.5 V LM4132, which is pretty good for 3200-count and 4000-count meters, but forces going up a scale on this 2000-count meter. However, I've also tried switching input polarity with inputs of about 190 mv, 1.9 V, and 19.9V (near the top of the 3 ranges) and the difference between positive and negative readings is usually 1 count there. The 7106 datasheet specifies a rollover error limit of +- 1 count so it's within that spec.
- Yes, the 20 A input has no fuse. I think this was once common; I also have a couple of handheld meters with 10 A or 20 A inputs and no fuse. Most of the time, I use this to measure AC line current, so there is a 15 A breaker upstream somewhere, but I understand that the unfused input is a real risk with an unfused high-current source (e.g. car battery). The 200 mA/2 A current input is fused; there is a 5 x 20 mm fuse inside the blocky-looking red input jack housing.
- I found a photo of the interior of GW-8035F, and it seems to be an older generation of instrument. It has nothing larger than a couple of 16-pin DIP ICs in it - no 40-pin DMM building block chip. The analog signal circuitry is quite different too.
- On the other hand, the 8034's circuit board has a bunch of unpopulated locations near the right edge (bottom of the first photo): U603 and U604, plus R113-R120. And there's a 7107 meter chip which has the same functions as the 7106, but its outputs are designed for driving LEDs instead of a LCD. So I wouldn't be surprised to find a version of this meter with LED display.
- 300 Hz is the frequency used for capacitance measurements in this meter. Thus the test point labelled "300 Hz POINT" is probably part of the capacitance to voltage converter. The capacitor jacks are connected to the main board by 4-pin J401. So VC401 right next to it could be part of the capacitor measurement, or it could be a high-frequency adjustment for the AC converter.
- U101 (main voltage regulator) is a 7808 regulator. It may look a little discoloured, but it was only slightly warm to touch when I checked it. The whole meter draws only 0.9 W/1.3 VA when operating. Of that, 0.6-0.7 W and 1.1 VA is drawn when the power switch is turned off. The power switch is electrically between the transformer secondary and the rectifier diodes, so the transformer draws magnetizing current even when the meter power switch is off.
