Author Topic: Maynuo M8811 inside pic  (Read 16078 times)
Re: Maynuo M8811 inside pic
« Reply #25 on: July 20, 2013, 05:17:40 am »
Yes, they have an internal spring that keeps the think locked at all times, and provides holding force to the cable end to make secure contact.
Offline metalphreak
  • http://d.av.id.au
    • D.av.id.AU
« Reply #26 on: July 20, 2013, 05:37:25 am »
It doesn't hold very small gauge wire properly. Adding a wire ferrule crimped on the end gives it a larger size and something rigid to push into the connector.
Offline crtTopic starter
  • Country: id
  • LLLLLLL-RGDSLLL-DSARLLL-LLLLLLL
« Reply #27 on: July 20, 2013, 11:51:29 am »
Thank's for your information
Everything is work fine :)
Next, I will update/edit my post about Low Voltage / Max Current test (about 5-6 hour)
  • Country: id
« Reply #28 on: July 20, 2013, 01:10:18 pm »
FWIW, the power designs precision supply can output its rated current down to ~ 3mV before it rolls off, compared to your unit of ~ 292mV.
After using Sensing Wire
here last result
Setting Voltage (Max Current) ==> Voltage Reading (DMM) and Constant Current 5A
0.30V @ 5.1A ==> 0.299V @ 5.0070A
0.25V @ 5.1A ==> 0.249V @ 5.0072A
0.20V @ 5.1A ==> 0.200V @ 4.7835A
0.15V @ 5.1A ==> 0.149V @ 3.5871A
0.10V @ 5.1A ==> 0.100V @ 2.3916A
0.05V @ 5.1A ==> 0.049V @ 1.1765A
Current start to drop below 5.0A @ 0.211V
At 0.002V setting ==> reading 0.001V at DMM @ 0.0209A
Current start to ZERO when setting at 0.001V ==> reading 0.000V at DMM
  • Country: id
« Reply #29 on: July 30, 2013, 04:33:49 pm »
You should program the PSU for 10V/5A and the eload to 10V 5A, then 10V .05A alternating say at 1 sec intervals, and check if the PSU actually produces that output and the response waveforms; this can be very stressful on PSU and can damage them if you do this for long periods.  That load will simulate radio transmission [ or cellphones if you set it to 3.5V instead] alternating between send and quiescent.
I had try dynamic load as you suggest
DS load (CC) 5A@1s // 0.05A@1s
PSU 10V@5A, but when turn it on, Voltage drop to 0.234V
so i increase current to 5.05A
anyway, how to set PSU for Constant Voltage ?
Switch-on performance with 5A load (5.010A @ PSU)
Switch-on performance with 5A load (5.015A @ PSU)
Switch-on performance with 5A load (5.020A @ PSU)
Switch-on performance with 5A load (5.025A @ PSU)
Switch-on performance with 5A load (5.030A @ PSU)
Switch-on performance with 5A load (5.040A @ PSU)
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #30 on: July 31, 2013, 06:17:12 pm »
@ crt, these look very good, no spikes.  Not like this PSU:
https://www.eevblog.com/forum/reviews/beware-yihua-yh-305d-bench-psu/30/
Best Wishes,
 Saturation
  • Country: id
« Reply #31 on: August 01, 2013, 09:01:21 am »
I just realize when viewing Dave review about atten psu, and some other psu
This M8811 looks like do not have multitaps output at transformer
I heard relays clicks only when switch form local to remote sense and vice versa ?
Offline metalphreak
  • http://d.av.id.au
    • D.av.id.AU
« Reply #32 on: August 01, 2013, 10:42:21 am »
Looking at the transformer, the only decent output rail with sufficient current is the 40V 7.1A one. I wonder what sort of topology they are using? It's meant to be a linear supply right?
Do you have an AC power meter? Would be interesting to see the power draw when its only putting out a low voltage/high current.
  • Country: id
« Reply #33 on: August 01, 2013, 02:19:50 pm »
Yes, agreed with you.
I just read manual, i found M8811 is Programmable DC Power Supply (don't know this is linear or not), only M8831 that says Programmable Linear Power Supply
unfortunately i dont have AC Power meter  :-[
Extra pic
5-0-10-0-15-0-20-0-25-0-30-0 Volt Sequence (@50ms) without load
5-0-10-0-15-0-20-0-25-0-30-0 Volt Sequence (@50ms) with 5A load
« Last Edit: August 01, 2013, 06:13:56 pm by crt »
