To acbern,
The 6622-base model is just a digital version of the 9930 which is all analog, the base specifications of both models are the same. Both models also had/have upgrades available to increase accuracy and also the current ranges of the base models. The fact that the 6622 has a digital readout doesn't make it any better than the 9930 which has no digital readouts. Digital, by itself, does not make anything better or more accurate, that seems to be a common misconception. Personally, I rather like analog readouts, they have no steps and better resolution in many cases, no flip-flopping digits. I've got digital readouts on some of my instruments and often they fall short of the analog readouts.
Resolution alone does not mean anything, it does not add to the accuracy of the measurement in most cases and has inherent limitations in the digital logic. The 9930 surpasses the accuracy requirements of any lab but a primary standards lab of very high calibre. The 9930 and 6622 do not have built in resistance standards, they are comparators of high accuracy, you must have reference standards for these units to compare to. They are not a resistance bridge.
