Ok, just barely getting started with the Maynuo M9712. So far, so good. More to come later but here is a photo showing that the gear is displaying the following values:
Korad KA300P Power Supply (in Constant Voltage mode)
Volts 1.16 (set for 1.16 and presumably delivering 1.16)
Amps 1.002 (set for 1.055 max and supposedly delivering 1.002)
Maynuo M9712 Electronic Load (operating in Constant Resistance mode)
Volts 1.004
Amps 1.0034 (governed by CV set on PS and CR on EL)
Watts 1.01
Ohms 1.00000 (set for 1.00000)
Radio Shack 22-812 DMM
Volts 1.155
Fluke 179 DMM
Amps 1.004
Lots of test leads too long; I'm working on getting those shortened up. Also trying to figure out what discrepancies are based on test lead resistance, and what is based on equipment not displaying accurate values. I'm pretty sure the RS reads about 5 millivolts lower than the Fluke on values around 1.5 volts. My hunch is that the Fluke and the Maynuo might be pretty accurate and the Korad and RS are a tad behind but before I go too much further I'm going to see if I can dial it all in a little better.
One initial comment on the Maynuo. It's number one feature so far is the ability see Volts, Amps, Ohms, and Watts simutaneously on the display.
Special thanks to LaurenceW for handholding me through Maynuo 101 and 102.
EF
