Hi eevblog.
Last year I discovered an unknown chinese current clamp ETCR008.
Range AC 0.0mA ~ 30A
Resolution AC 0.01mA
Frequency characteristics: 10Hz ~ 100kHz
I liked the frequency characteristics: 10Hz ~ 100kHz from the data sheet so
I ordered one and made an impedance/phase plot from 10Hz-200khz using my 14bit swiss army knife analog discovery 1.
The first resonance frequency appears around 4.8Khz which is a bit too low for me for oscilloscope usage.
ETCR008
Accuracy class 0.5% FS (50Hz / 60Hz; 23 ℃ ± 2 ℃)
Turn ratio 2500: 1 (choose 2000: 1; 1000: 1)
Line voltage AC 600V line test
Current frequency 45Hz ~ 60Hz (measured current frequency)
Insulation strength AC3700V / rms (between core and case)
Phase error ≤2 ° (50Hz / 60Hz; 23 ℃ ± 2 ℃)
Reference load
RL: 0 ~ 300mA≤500Ω; 0 ~ 3A≤50Ω; 0 ~ 30A≤5Ω
https://item.taobao.com/item.htm?id=580782994199So maybe save your money if you intend to use it on higher frequencies.
My first post here? Could be.
Greetings.
Dip_Switch
