Author Topic: Got my GDM-8251 from eBay today...one question  (Read 15790 times)
Offline xrunner
  • hp>Agilent>Keysight>???
Re: Got my GDM-8251 from eBay today...one question
« Reply #25 on: January 29, 2017, 12:39:57 am »
They could've put a resistor between pins 1 and 4 to prevent a complete short circuit when plugged into a real USB port.
But that would have cost an extra few cents per unit.  :-//
Offline bitseeker
« Reply #26 on: January 29, 2017, 12:43:49 am »
Yeah, I was going to say that, but for the price they're charging, they can afford it. ;D
Offline sequoia
« Reply #27 on: February 05, 2017, 08:01:40 pm »
Response from GW Instek:
>The issue is caused by dynamic range. For GDM-8255A/8251A, customer need to manual set the range for it.
>The newer model like GDM-834x or GDM-8351 has already solve this issue.
Yep.
I ordered the GDM-01 cal key from Tequipment, but then found out that they couldn't ship it until March 28, so I had to cancel that order. I found the key for sale on Ebay so it should be here in a few days. I also got the firmware file from GW Instek, so I'm ready to try the upgrade as soon as I get the cal key, via the RS-232 serial connection.
Did it take long to get response from GW Instek?  I requested firmware via their "contact us" web form at www.gwinstek.com maybe a week ago but so far no reply...
Offline xrunner
« Reply #28 on: February 05, 2017, 08:19:15 pm »
Only took 24 hours. Here's the email address I wrote to -
services@goodwill.com.tw
Offline sequoia
« Reply #29 on: February 07, 2017, 06:14:48 am »
Thanks, that email address worked.  Still waiting to receive some USB connectors I ordered from eBay, so I can make my own "CAL key" with small resistor soldered between pins 1 and 4 inside the connector....
If firmware upgrade is successful, then need to figure out if there would be some place in Southern California to get this thing checked/calibrated at reasonable cost.... (
Offline xrunner
« Reply #30 on: February 08, 2017, 12:00:52 am »
Cool!
If ... if? Of course it will be successful!  :)
Been using mine quite a bit. As a matter of fact was just using it to monitor the temporary RAM voltage I applied to my HP 3457A while I replaced the backup battery. That's something I did not want to make a mistake on because the ram-(no pun intended)-ifications would have been unpleasant..  :phew:
Offline sequoia
« Reply #31 on: February 09, 2017, 08:27:46 am »
Got some USB (type-A) connectors from ebay (10 for $2.35 with free shipping) to make my own "cal key".
First, I soldered 100 ohm resistor across pins 1 and 4, but unit didn't enter calibration mode on boot (simply booted up normally). Next, I tried shorting pins 1 and 4 and that worked!
Firmware upgrade was successful with the home made "cal key"...
The following users thanked this post: CustomEngineerer
Offline xrunner
« Reply #32 on: February 10, 2017, 12:00:12 am »
10 for $2.35 ... Considering the ridiculous price they are being sold for, you could make a killing selling home made cal keys.  ;)
Offline BloodyCactus
    • Kråketær
« Reply #33 on: February 10, 2017, 01:56:12 pm »
someone must be sitting on a metric tonne of original cal keys because one comes with each unit when its purchased. if all these are hitting ebay with no cal key. someone is hoarding them lol!
-- Aussie living in the USA --
Offline bitseeker
« Reply #34 on: February 10, 2017, 07:18:40 pm »
Since the bulk of these units are from the ITT liquidations, someone might have them. But, more likely, they were tossed as extraneous accessories.
Offline frog7227
« Reply #35 on: February 13, 2017, 12:22:54 am »
A little bit of a thread hijack here , but here it goes.
After lots of pain with the original GW-Instek DMM Viewer...
I wrote program to communicate with a PC in Java.
At the moment it needs the RXTX library installed system wide.
I've only tried it on Windows, I'll be trying it on Linux later.
I'll offer a .jar version once I've compiled and compressed everything (Including RXTX).
Link: https://github.com/frog7227/SerialInterface
If you have any issues or proposals for features post them on my Github, I'll see them much faster that way  ;).
The following users thanked this post: xrunner, gnavigator1007, theirishscion, analog8484
Offline xrunner
« Reply #36 on: February 13, 2017, 12:25:44 am »
Cool - we like that kind of hijacking.  :-+
Offline CustomEngineerer
« Reply #37 on: March 03, 2017, 05:06:06 am »
Shorting pins 1 and 4 also worked for me. Had an extra usb connector laying around so copied sequoia's key. Thanks for showing pics.  :-+
