Author Topic: Good voltage regulator tester?  (Read 364 times)
Offline AxtmanTopic starter
« on: July 21, 2024, 11:43:05 pm »
Is there a good, inexpensive voltage regulator tester? Most transistor regulators I want to test are from 5 to 18 volt.
Online Kim Christensen
Re: Good voltage regulator tester?
« Reply #1 on: July 22, 2024, 03:22:37 am »
Probably better to buy a power supply and an electronic load. Those would be useful for other tasks as well, as opposed to a dedicated regulator tester.
Offline JoeyG
« Reply #2 on: July 22, 2024, 04:57:40 am »
You could look at a regulator  data sheet like the classic LM7805  and see what parameters  are critical for you and these theses.
https://www.sparkfun.com/datasheets/Components/LM7805.pdf
Datasheet used to give clues in the test method but now they don'.t
Offline Messtechniker
« Reply #3 on: July 22, 2024, 06:15:50 am »
Some time ago I rolled my own:
Agilent 34465A, Siglent SDG 2042X, Hameg HMO1022, R&S HMC 8043, Peaktech 2025A, Voltcraft VC 940, M-Audio Audiophile 192, R&S Psophometer UPGR, 3 Transistor Testers, DL4JAL Transistor Curve Tracer, UT622E LCR meter, UT216C AC/DC Clamp Meter
The following users thanked this post: Electro Fan
Offline indman
  • Country: by
« Reply #4 on: July 22, 2024, 06:31:40 am »
A transistor tester that has a high-voltage voltage source in its circuit for testing zener diodes can easily be converted into a voltage regulator tester. A photo of such a modification is below. ;)
