Thank you guys for the replays
What is mean is that if I try to use 50ms, 100ms or higher settings, I don’t get a real time
display of the signal, there is a large delay (latency) or a “stuttering” display of the wave form.
I’ve also tried a PC based scope (using a parallel port) but it won’t go anywhere above 100ms, and starts to fail even at 10ms.
If any of you guys have RIGOL/SIGLENT/OWON – or any of these cheapo scopes, I’m appreciate it if you could check the 250ms and above (time base scale) and let me know how they behave.
Thanks,
Assaf
